Anyone using motor mount inserts. If so what brand.
Old May 21, 2003 | 07:47 PM
93si's Avatar
Default Anyone using motor mount inserts. If so what brand.
I am trying to make my motor solid.
Old May 22, 2003 | 11:51 AM
lazyvietboi's Avatar
Default Re: Anyone using motor mount inserts. If so what brand. (93si)
I heard http://www.jimfab.com is the most solid (sp) motor mounts you can get.
Old May 22, 2003 | 11:54 AM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
Default Re: Anyone using motor mount inserts. If so what brand. (lazyvietboi)
Prothane
Old May 22, 2003 | 12:22 PM
NonovUrbizniz's Avatar
Loved
Default Re: Anyone using motor mount inserts. If so what brand. (Apex i ITR)
ES... they're not too stiff.
Old May 22, 2003 | 12:27 PM
StreetRacnGsR
Guest
Posts: n/a
Default Re: Anyone using motor mount inserts. If so what brand. (NonovUrbizniz)
I use custom billet solid mounts. I made them at a machine shop best way to get the power to the ground. Look better than jimfab too. but i wont make anymore.
Old May 22, 2003 | 12:38 PM
B.'s Avatar
B.
400 HP Club
Default Re: Anyone using motor mount inserts. If so what brand. (StreetRacnGsR)
i have jimfab in mine and they kickass, easy to insert and **** stiff.
Old May 23, 2003 | 10:14 AM
-Trinitron-'s Avatar
I got the black evergy suspension mounts, firmed it right up but doesn't shake at idle...chicks don't dig the shake!
Old May 23, 2003 | 10:21 AM
SikofFalln's Avatar
Default Re: Anyone using motor mount inserts. If so what brand. (SlowBlueSi)
I have energy suspension mounts, but if I could get any I would go with InlinePro mounts, although the JimFab look to be the most bang for your buck.
GARBhatch.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlowBlueSi &raquo;</TD></TR><TR><TD CLASS="quote">I got the black evergy suspension mounts, firmed it right up but doesn't shake at idle...chicks don't dig the shake!</TD></TR></TABLE>Yah i got the place racing mount for just the driverside motormount on my EK. Def shakes more than expected, but never worrying about breaking that mount again. PLACE RAcing fitment sucks, but if you get one just shave the seam sealant first. Don't bang the fenders out.
Old May 23, 2003 | 10:52 AM
StreetRacnGsR
Guest
Posts: n/a
[QUOTE=SlowBlueSi]I got the black evergy suspension mounts, firmed it right up but doesn't shake at idle...chicks don't dig the shake![ /QUOTE]
why do you care if chicks dont like the shake of the idle. you should mod your car for the love of your car not just so chicks will like you..
Old May 23, 2003 | 10:53 AM
Pritos's Avatar
New User
Default Re: Anyone using motor mount inserts. If so what brand. (98Hatch00)
I use the Energy Susp for the front lower 2 and rear.. then filled the front uppers solid with black silicone.
Old May 23, 2003 | 10:59 AM
gitwidit's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Apex i ITR &raquo;</TD></TR><TR><TD CLASS="quote">Prothane</TD></TR></TABLE>
not to rough but you can deff tell the difference
Old May 23, 2003 | 12:14 PM
ill phil's Avatar
Default Re: Anyone using motor mount inserts. If so what brand. (GITWIDIT)
ES on mine, very little vibration at idle and it helped out a lot. Can't beat a $30 investment like that.
Old May 23, 2003 | 12:36 PM
allmtr's Avatar
Default Re: Anyone using motor mount inserts. If so what brand. (ill phil)
i got the j's racing engine dampener... works great
exhale
Sep 7, 2007 05:30 PM
white_db8
May 26, 2007 09:34 AM
ahemming06
Feb 20, 2007 01:27 PM
integrawow
Suspension & Brakes
Nov 10, 2006 09:48 PM
ComputerJLT
Jul 2, 2004 02:25 PM
