Is a t25 oil exit flange the same as a t3?
Like the subject says... Friend has a 2nd gen eclipse t25 and I'm putting together the oil lines for it. There are plenty of t3 drain flanges to be found, but not too many t25 to be found - are they the same size?
Thanks all...
Thanks all...
sr20performance sells t25 oil exit flanges. I wish I knew if they would fit a T28 also.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1114 »</TD></TR><TR><TD CLASS="quote">sr20performance sells t25 oil exit flanges. I wish I knew if they would fit a T28 also.</TD></TR></TABLE>
Mike, T25 and T28 is the same flange
stan
stan
Strangely enough, the T25 drain flange I bought from SR20performance does not fit my T28... It will after modification tho... It's a Nissan Pulsar GTi-R T28, BTW... T25/T28s are just plain wierd turbos...
