GT3040 Update pics + Downpipe 80% installed
Old May 21, 2003 | 06:38 PM
BLKCRX's Avatar
Default GT3040 Update pics + Downpipe 80% installed
Hey all here’s the pictures I promised I would post up of my downpipe and custom dump tube for my GT3040 for those that wanted to see the rest of the pics
Iv moved the radiator and a few other things…
The new Pics can be found at
http://home.themaestro.net/blk...x.htm
The 1st set of pics I posted can be found at
http://home.themaestro.net/blkcrx/gt3040/index.htm
Currently im waiting on my intercooler pipes to get power coated, I should start my car again in a few days… then onto the dyno sometime next week
Enjoy Regards James
Old May 21, 2003 | 06:39 PM
shortyz's Avatar
Default Re: GT3040 Update pics + Downpipe 80% installed (BLKCRX)
looks great
Old May 21, 2003 | 06:41 PM
bottlefedb18c1's Avatar
nice what kind of whp are you shooting for?
Old May 21, 2003 | 06:43 PM
BLKCRX's Avatar
Default Re: (bottlefedb18c1)
well i was making 300HP+ with 20psi before on a small t3t4 turbo.. so yeah this GT3040 is much larger... iv got a fully built b16 so yeah... 400HP+ or so maybe more.. i guess i won't know untill im on the dyno....
Regards James
Old May 21, 2003 | 06:45 PM
hope it all works out for you with that
Old May 21, 2003 | 06:48 PM
DubyaAye's Avatar
how thick does the metal has to be for the dp, i need a new dp.
Old May 21, 2003 | 07:50 PM
BLKCRX's Avatar
Default Re: GT3040 Update pics + Downpipe 80% installed (DubyaAye)
hmmm im not sure how thick.. but i know the material were using is thicker than what my original max rev down pipe was using... it would have to be at least 3mm or 4mm thick...
Regards James
Old May 21, 2003 | 07:51 PM
TurboSedan's Avatar
New User
Good luck reaching your goals! Your setup looks very nice!
Old May 21, 2003 | 08:05 PM
int3gra's Avatar
Default Re: GT3040 Update pics + Downpipe 80% installed (TurboSedan)
excellent pictures man, good luck with completing it.
Old May 21, 2003 | 08:15 PM
Cyber ITR's Avatar
Default Re: GT3040 Update pics + Downpipe 80% installed (int3gra)
is that a t3 or t4 exhaust housing ?
Old May 21, 2003 | 08:21 PM
BLKCRX's Avatar
Default Re: GT3040 Update pics + Downpipe 80% installed (SEX DR)
GT30 (GT3040) turbos are a t3/t4 type turbo.. i belive...
t3 exhaust
t4 intake...and duel ball bearing....
the specs on the turbo is .82 on the exhaust and .70 on the intake side.
I wanta take the boost to 20psi + maybe 25...
Regards James
Old May 22, 2003 | 11:13 PM
SiRkid's Avatar
Old May 23, 2003 | 02:08 AM
Cyber ITR's Avatar
Default Re: GT3040 Update pics + Downpipe 80% installed (SiRkid)
does GT30 / GT35 have a big shaft , like T-series ?
Old May 23, 2003 | 02:37 AM
BLKCRX's Avatar
define what you mean by a big shaft ???
Regards James
Old May 23, 2003 | 08:09 AM
KCHybrid's Avatar
Nice looking setup, if you dont mind me asking where did you get your turbo? It is very close to the same spec I am wanting to get. When do you expect full boost?
to a nice setup
Old May 23, 2003 | 11:19 PM
rca90gsx's Avatar
99% sure they both still use the smaller shafts.
Richie
NSCRA
Feb 23, 2010 06:21 PM
huy.
Sep 11, 2005 12:54 PM
goodamu
Dec 31, 2003 06:02 PM
Bongnak
Jul 29, 2003 03:17 PM
BLKCRX
May 20, 2003 06:46 PM
