GSR puting skunk2 manifold on... quick question...
one more question,
Where the coolant line goes into the skunk2 manifold, what about the second coolant line under.. the gsr does not have another coolant line..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jordo »</TD></TR><TR><TD CLASS="quote">one more question,
Where the coolant line goes into the skunk2 manifold, what about the second coolant line under.. the gsr does not have another coolant line.. </TD></TR></TABLE>
I just re-routed the extra coolant nipple to a tee to the existing heater hose. You can use it if you're running external turbo cooled.
stan
stan
just plug it up....on my brother's gsr I used a piece of rubber hose and plugged the end of the hose up with a bolt and hose clamp. Then I put this on the second coolant line you are talking about and clamped it.
