need help ASAP
Old May 21, 2003 | 05:58 PM
bOOsTiNSoHcVtEc's Avatar
Default need help ASAP
swapped a b18b into my 95 civic ex and also converted it from auto to manual...everything is plugged up and it jus wont crank over...it doesnt even try to start...someone please help...i need some ideas by tomorrow...thanks
Old May 21, 2003 | 06:07 PM
domestik2k's Avatar
put gas in it!!! ha ha, it wont crank??? whats it doin? chek all fuel line, ignition....is it gettin any fire??? b more specific budd
hndarcrb18c1's Avatar
Default Re: need help ASAP (bOOsTiNSoHcVtEc)
Need more details!!! do the dash lights come on??? does it even turn over or do you get nothing when you try to start it?????
Old May 21, 2003 | 06:10 PM
domestik2k's Avatar
exactly.... specifics wood b great. hell u got the battery bak in????
Old May 21, 2003 | 06:11 PM
Default Re: need help ASAP (hndarcrb18c1)
yeah the dash lights come on...and i turn it to start it and nothin happens at all...i hear nothing
Old May 21, 2003 | 06:12 PM
Neptune's Avatar
ignition is your friend, need a lot more details.
EDIT you posted too fast. Check the ignition wires. Spark plugs too. Fuel lines... did you install everyhitng yourself?
Old May 21, 2003 | 06:17 PM
blackhatchy's Avatar
Default Re: need help ASAP (Neptune)
yah make sure the dis. wires are on the right plugs, i got mine out of order, and freaked out, but when i realized that was the problem, i felt like a jackass
Old May 21, 2003 | 06:37 PM
i changed the spark plugs..the fuel lines are all okay and the ignition wires should be okay but i will check tomorrow...i installed it with my friend and we checked everything with a test light so we know the starter is okay
Old May 21, 2003 | 06:41 PM
mafioso102's Avatar
New User
have you charged your battery? Just because the dash lights and radio come on it doesnt mean that the battery has enough juice to start the car. Pull the battery and test it.
Old May 21, 2003 | 06:46 PM
Default Re: need help ASAP (mafioso102)
we put a battery charger on it but it kept reading 0 amps...i dont know if something was wrong with the charger or what...maybe we'll try to jump start it with another car
Old May 21, 2003 | 06:58 PM
deepnite's Avatar
could be the alternator too..it ll try to crank but nothing will happen
Old May 21, 2003 | 07:04 PM
Eg6LazyPt's Avatar
Default Re: need help ASAP (deepnite)
Well if it didn't even crank at all and you think you did everything correctly check your ground. If the motor is all good and setup correctly but no crank at all, its usually ground.
Old May 21, 2003 | 11:52 PM
Default Re: need help ASAP (Eg6LazyPt)
Chech the wire with the spade connector on the starter make sure it has 12v when trying to crank. Also the battery charger is reading 0 amps becasue that how many amps the batt is pulling (its fully charged)
Old May 22, 2003 | 09:31 AM
dantastic's Avatar
so nothing is happening at all? no turning? its probably the starter
Old May 22, 2003 | 03:21 PM
civicVX's Avatar
check the small female plug that goes to the starter. assuming that you are not hearing anything at all. make sure your grounds are hooked up in the engine compartment.
Old May 22, 2003 | 07:19 PM
Thats the thing...it has power going to the starter but when i try to crank it the circuit tester light goes off and i changed starters too so i know it isnt the starter. Today a mechanic at the shop told me it might some kind of neutral lock mode in went in to...cuz in automatics sometimes wen you turn it off in gear it doesnt let u start it back up in park, you have to start the car in neutral...so if anyone knows a place online with wiring diagrams for a 95 civic ex please tell me cuz i need to find the wire or wires. Me and my friend basically checked everything and that looks like its the problem.
Bryantcuhz
Jul 27, 2014 05:04 PM
j4s0n1337
41
Feb 19, 2011 07:50 PM
emperor559
Jan 11, 2008 01:56 PM
kingmonkey
May 14, 2005 09:14 AM
bOOsTiNSoHcVtEc
May 21, 2003 08:27 PM
