check engine light at high rpms
Old Jul 11, 2001 | 11:40 PM
Turbohatch's Avatar
New User
Default check engine light at high rpms
i have a b16 turbo with a apexi v-afc when im full throtle and when it gets around 7500 rpm my engine cuts off and check engine comes on. It doesnt respond to gas after that until i turn the car off and back on then its fine. ???????? please i need some help
[Modified by Turbohatch, 7:51 PM 7/12/2001]
Old Jul 12, 2001 | 08:21 AM
TypeC's Avatar
Default Re: check engine light at high rpms (Turbohatch)
first off, what code are you throwing? what percent (max) fuel are you adding (over about 10-12% causes a code)?
Old Jul 12, 2001 | 10:48 AM
Turbohatch's Avatar
New User
how do i know what code im throwing??????????????
Old Jul 12, 2001 | 11:00 AM
bps2799's Avatar
Find your service connector, then bridge the contacts w/ a paperclip. Long flashes of the check engine light are tens place, short flashes are ones place.
Old Jul 12, 2001 | 01:39 PM
Turbohatch's Avatar
New User
Default Re: check engine light at high rpms (bps2799)
is that the problem for sure and is there anywhere where i can find a diagram and the check engine light stays on until i turn my car off
[Modified by Turbohatch, 10:40 PM 7/12/2001]
Old Jul 12, 2001 | 01:42 PM
thinkbrianthink's Avatar
turbo hatch...
check out http://www.hondata.com/techecucodes.html to diagnose the problem code.
hope that helps.
brian
Old Jul 12, 2001 | 08:00 PM
Turbohatch's Avatar
New User
someone said i need a fuel cut defence ??????????????
Old Jul 12, 2001 | 08:13 PM
Turbohatch's Avatar
New User
im throwing code 3 (Map) and code 16 fuel injectors what is the problem
67tj67
Oct 4, 2018 11:38 AM
98dxkoupe
Oct 2, 2018 04:32 PM
importdude2000
Jul 17, 2004 12:53 PM
wadafa
11
Oct 3, 2002 03:49 PM
Turbohatch
Jul 13, 2001 08:27 AM
