check engine light at high rpms
New User
i have a b16 turbo with a apexi v-afc when im full throtle and when it gets around 7000 rpm my
engine cuts off and check engine comes on. after that when i push on the gas it doesnt respond
until i turn the car off then back on, its throwing code 3 (MAP) and code 16 (fuel injectors)??????? help
[Modified by Turbohatch, 2:05 PM 7/13/2001]
Re: check engine light at high rpms (Turbohatch)
you probably have it leaned out to far..... what do you have your fuel cut set at anything below -7 or 8 is gonna lean the car out to far ? and where is the vtec set ?
Re: check engine light at high rpms (Inaniac)
reset your vafc to stock settings....reset your ecu...if the light doesn't come back on...you have found your problem
