ODB2 motor in ODB0 car...
is this even possible? what needs to happen in order to make it possible. we are trying to get an 00 d16 into an OBD 0 rex...what all needs to be changed? i searched and can never make any sense out of OBD related posts. thanks in advance!
this is really easy. Take off all the wiring harness that comes with the 0BD2 motor (dizzy too). Then use your old D series wiring (ecu, dizzy, and stock wiring harness) and everything should just click togeathor. Unless your motor is VTEC that your putting in, thats it if you have VTEC you will have to use a VTEC activating switch of somekind.
Really easy if you have any more Qs IM me.
Blaze
Blaze
