total seal rings....w/h22a questions
Old May 21, 2003 | 02:42 PM
Log4n's Avatar
Default total seal rings....w/h22a questions
engine just rebuilt w/total seal rings......200 miles so far.......lots of blowby.....during the process my mechanic was told not to hone the block....therefore he didnt......no instructions came in the packaging for the rings from total seal.......are these rings going to seat?
engine info-h22a w/stock pistons and the block was not re-sleeved
Old May 21, 2003 | 04:52 PM
non-VTEC's Avatar
Default Re: total seal rings....w/h22a questions (Log4n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Log4n &raquo;</TD></TR><TR><TD CLASS="quote">.....during the process my mechanic was told not to hone the block....therefore he didnt.......are these rings going to seat?
who told your mechanic not to hone the block?
chances are that the rings will never properly seat so you will always have an oil consumption problem........
i do belive total seal does have a special cylinder wall honing spec/procedure or something like that. you should call them and find out.
Old May 21, 2003 | 05:10 PM
Furry in your eye
Guest
Posts: n/a
Default Re: total seal rings....w/h22a questions (non-VTEC)
first off total seal rings are ****, 2nd off your mechanic is a ****** dumbshit... may as well tear it apart now cause them rings are never gona seat
Old May 21, 2003 | 07:21 PM
91integraLSVTEC's Avatar
a moderator should make a sticky post saying total seal rings are shitty!! damn there much more expensive than oem honda rings and there hard to seat.. if they do they rob horsepower.. i have total **** rings in my ls/vtec and i get lots of blow by about 185psi across the board on my 12:1 motor..
Old May 21, 2003 | 11:24 PM
aeolus's Avatar
Default Re: (91integraLSVTEC)
Those rings are not made for the stock block.They will never seal.
xxmastermindxx
Dec 8, 2007 10:28 AM
toofast4u752
May 8, 2006 04:32 PM
jerseydevil
Apr 4, 2004 07:29 AM
Log4n
May 21, 2003 09:06 AM
90crxzc
May 3, 2002 08:49 PM
