Cams and Cam Gears
So I have to get a new timing belt, and I figure I can do the cams and cam gears at the same time. The only problem I am wondering is if I will have to do lots of tuning once I install the parts? Will I need a dyno? Or can I just install and leave it?
NVBAM: Are you changing your cams and cam gears b/c of this thread: https://honda-tech.com/zerothread?id=503039
If you are doing it anyway, mild cam upgrades won't hurt anything, but it's always a good idea to tune it so you get the most out of your money. And before you ask set the cam gears to 0,0.
misterpsycho
Jan 14, 2008 10:54 AM
