mixed D series parts...
Old May 21, 2003 | 07:25 AM
v4lu3s's Avatar
RTFM
Default mixed D series parts...
ok im about to build a motor, i have a great condition d16y7 block and crank, and want to put in a set of eagle rods and srp pistons...
I have the eagle d16 rods now, but SRP shows diff parts #s for the vtec and non vtec pistons. does it really make a diff? I will be putting a d16z6 head on the block though. was wondering if anyone can point me in the right direction....thanks!
Old May 21, 2003 | 03:17 PM
vladd's Avatar
Default Re: mixed D series parts... (v4lu3s)
i always thought the y7 and y8 have the exact same pistons.
Old May 21, 2003 | 03:58 PM
kommon_sense's Avatar
Default Re: mixed D series parts... (civicdxtyper)
If you are using a z6 head, then I would look into z6 pistons. any d-series pistons should fit in the block. The issue will be what head you put on. Not all d-series heads have the same sized combustion chamber. For example, some 9.5:1 pistons for a y8 head will probably yield somewhere around 9:1 with a z6 head. And some 9.5:1 pistons for a z6 head will probably yield around 10:1 with a y8 head.
Old May 22, 2003 | 05:48 AM
v4lu3s's Avatar
RTFM
Default Re: mixed D series parts... (kommon_sense)
thanks
ill definitely be going with d16z6 pistons.
i was also concerned about valve reliefs as well, since i had thought the vtec head had slightly larger valves as well.
Old May 22, 2003 | 07:59 AM
yaya's Avatar
i have a d16z6 that im parting out
runs/ran like a champ
Old May 22, 2003 | 09:08 AM
94hatch's Avatar
Default Re: mixed D series parts... (yayaRl337)
I believe the Y7 Y8 motors have a different piston to deck height which affects the overall C/R. I am using 10.5:1 D16Y8 pistons in my Z6 motor and they yield 9.51:1 compression.
Txdragon
Engine Machining & Assembly
14
Feb 10, 2018 04:53 AM
ERKK
27
Sep 19, 2008 06:20 PM
baphomet
Jun 7, 2006 12:28 PM
green91
Nov 15, 2005 07:07 PM
douspray
Jun 24, 2005 10:35 AM
