B16A Distributor Help!!!!
Old Jul 12, 2001 | 02:26 PM
Jared's Avatar
Default Re: B16A Distributor Help!!!! (joedr)
No, the only non-OBD distributor that will bolt to that B16A1 head is a B16A1 distributor. However, it does use 90-91 Integra and 88-91 Civic internal parts.
good luck,
Jared
Old Jul 12, 2001 | 05:42 PM
TheShad0w's Avatar
Default Re: B16A Distributor Help!!!! (Jared)
yeah, im running a b18b's distributor in my b16a3.. works great
Old Jul 12, 2001 | 06:00 PM
raene's Avatar
Jared,
Does that mean a CRX Si igniter will fit a B16A distributor? Thanks in advance .
Here's the B16A resource quote on the distributor...
The distributor is a harder find as only the JDM one is truly a bolt-on fix. You can use the '90-1 Integra distributors provided you knock off one of the mounting legs - otherwise it will not bolt on. In the case of EFs the '92-3 GS-R ones will not work as they will expect to be mated up to an EG style engine harness.
Benz_05TSX
Jan 23, 2015 05:45 AM
IEATLINT
Jun 28, 2004 02:09 PM
EG6AAARRR!!!
Mar 7, 2004 03:55 PM
roadawg
34
Sep 2, 2003 08:44 PM
