1.9 60ft on falken azenis
Rt.66 is one of the best prepped tracks, period.
BTW: I saw your car the other day...super-clean.
We'll see if I can bust that record when my car gets off jackstands.
Suprdave
Suprdave
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T3T495GSR »</TD></TR><TR><TD CLASS="quote">30 psi in tires, stock clutch, i launched around 5000 with slippage of clutch. you gotta be GOOD
can you elavorate on slippage of the clutch! the best i have gotten is 2.2 dropping the clutch at 3k, lot of wheel hop, on 32 PSI 15" azenis! your input will be appreciated!
</TD></TR></TABLE>can you elavorate on slippage of the clutch! the best i have gotten is 2.2 dropping the clutch at 3k, lot of wheel hop, on 32 PSI 15" azenis! your input will be appreciated!
lets see, i heat them up first for about 3-4 secs with the ebrake on.
then i get to the starting line adn i hold the clutch down and hold my revs aroudn 4k or so, then i wait till i see the second yellow and launch right before green adn i dont give it full gas right away, i let the clutch out slowly while giving it about 3/4 gas then i dump the clutch and give it full gas at the same time, INSTANT BOOST.
it takes lotf of practice
chingchong
27
Oct 26, 2002 12:59 AM
sushibug
10
May 27, 2002 09:18 AM
