Compression results
Old May 20, 2003 | 10:38 PM
5thgencivic's Avatar
Default Compression results
I recently ran a compression test on a B16A and my D16Z6. The B16A came up as:
#1=190 #2=172 #3=174 #4=162
D16Z6 was:
#1=170 #2=157 #3=164 #4=160
I didn't like what number 4 came up as on the B16. My motor(D16) has 100,000 miles on it. I'd like to pick up the B16 but am unsure about it. Motor runs great, no smoke. Both motors were warm. What I was wondering is should the motor be turned over the same for each cylinder or until the gauge stops for each cylinder? Thanks.
Old May 20, 2003 | 10:50 PM
Turbogixxer's Avatar
Default Re: Compression results (5thgencivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5thgencivic &raquo;</TD></TR><TR><TD CLASS="quote"> What I was wondering is should the motor be turned over the same for each cylinder or until the gauge stops for each cylinder? Thanks.</TD></TR></TABLE>
Yes, with in reason (turning it over 10 times to get a number is too many). The cylinders should be 10% of each other, so both motors are not in the best shape but the are ok.
Edit: the d16 is in pretty good shape
Old May 21, 2003 | 07:52 AM
Default Re: Compression results (turbogixxer)
bump
Old May 21, 2003 | 08:02 AM
Cltchbrnr's Avatar
The number 4 on the b16 is questionable. As for what I would do personally, is I would probably pick up the b16 with the thought of a basic rebuild first. At least rings, bearings, gaskets, and pumps. As well the head would need to be checked, compression can be lost there as well. Goodluck.
Old May 21, 2003 | 07:58 PM
91civicEX's Avatar
do you have the equipment to do a leakdown test? it would tell you where your loosing compression
thomabra001
Dec 11, 2010 12:16 PM
kPRO dz
Sep 6, 2009 07:55 PM
Powered by VTEC
Feb 3, 2008 08:36 PM
Amused
Oct 26, 2006 03:30 AM
Hybridize
Sep 22, 2003 03:12 PM
