im getting a code 91????
i swapped a b18b into a friends 96 ek. He is using an obd2 ecu and he gets a code 91. i know its the fuel tank pressure sensor but where do i look to fix this problem. where is the fuel tank pressure sensor and why would it through this code after a motor swap... please help... thanks
The 96 ek, if it is a hatch, does not have the PTANK sensor some specific models have them, but most do not that year. I am actually doing some research now with the help of "acuracing" to see what is required to add it to my 96cx. I am just using a JDM ecu at this point, so I dont see that CEL.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AVRj00neALLrace »</TD></TR><TR><TD CLASS="quote">its a 96 dx hatchback. Should i just tell my friend to use jumper and use a stock obd1 ecu instead of the us obd2 ecu?</TD></TR></TABLE>
that is definetly an option I would consider.
mwaedow
10
Nov 23, 2013 11:03 AM
