dash swap
Old May 20, 2003 | 06:16 PM
JdmCIVIC853's Avatar
Default dash swap
I have a 92 civic cx..it had grey interior so i swap some 92 vx interior in there but i kept my cluster and now the tach and speedometer dont work......the cluster that was in my cx was from and ex.....can someone tell me why it doesn't work or how to fix it?
Old May 21, 2003 | 02:05 PM
Default Re: dash swap (JdmCIVIC853)
i need help
nothign in the cluster is working .....the tach the fuel gauge hot gauge nothing help
Old May 21, 2003 | 02:06 PM
NonovUrbizniz's Avatar
Loved
you either un-plugged or tore a wire... there's no reason interior pieces would make you guages stop working...
check the fuse also.
Old May 21, 2003 | 02:56 PM
gezer's Avatar
Default Re: dash swap (NonovUrbizniz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NonovUrbizniz &raquo;</TD></TR><TR><TD CLASS="quote">you either un-plugged or tore a wire... there's no reason interior pieces would make you guages stop working...
check the fuse also.</TD></TR></TABLE>
interior should have noting to do with this... did u plug everything in when u hooked up the cluster?? recheck all the wires.
Old May 22, 2003 | 01:33 PM
Default Re: dash swap (gezer)
everything is pluged in....no fuses are blowen....
Old May 22, 2003 | 01:43 PM
Loved
you probobly pinched some wires in something.
Old May 22, 2003 | 02:34 PM
All the wires are fine....which fuses should i check...b/c its says theres no fuse to the cluster....some of the lights work on the cluster.....like when i hit my brights the bright light on my cluster comes on....but my blinkers don't work...
Old May 23, 2003 | 10:04 AM
wheres the fuses for the turn signals and the cluster at which ones are they? i need help
Old May 23, 2003 | 10:07 AM
Loved
there should be a fuse for the console... it's also for the brake lights on my car (93 ex.. should be the same for you..)
Do you have brake lights? not the indicator your actual brake lights in the rear...
the highbeam and other indicators are on a seperate fuse... the console lights are on their own fuse with the brake lights... check those.. that should do it.
Old May 23, 2003 | 02:34 PM
I dont know which fuse it is....i have brake lights but all the gauges and the bottom lights dont work.....can someone tell me were the fuse or fuses are....i have a chiltons but it just sucks...
Old May 23, 2003 | 03:55 PM
bry02908's Avatar
Whats the difference between those dashes? Y swap?
Old May 24, 2003 | 03:56 PM
Default Re: dash swap (bry02908)
the only difference one is black
Old May 25, 2003 | 11:10 AM
does anybody know which fuses go to the turn signals and the dash?
Old May 25, 2003 | 12:13 PM
NightKids's Avatar
Its the fuse that says back up lights
kelviiv
Apr 19, 2008 08:16 AM
honda_conversion
Jun 22, 2007 11:31 PM
Bryce
Apr 28, 2007 09:09 PM
JDM Vision
Jan 18, 2006 04:47 PM
CoolKat
Sep 11, 2002 02:27 PM
