transmission metal type.
Old May 20, 2003 | 06:11 PM
xXx Justin xXx's Avatar
Default transmission metal type.
cracked the tranny housing under the seal where the axel goes in on the driver side. tring to pry the POS axel back out. not sure what type of metal it is. i dont think it is cracked all the way through. wondering if it can be welded. thanks
Old May 20, 2003 | 07:34 PM
Default Re: transmission metal type. (SOHC Beast)
anybody... i have been having hell with this tranny and the driver side axel not going in, when i tried pulling it back out to try to get it straight it was jambed... so i pried harder and it finally cracked the bottom of the tranny housing. i just got this tranny like 2 days ago for my z6/ turbo set up.... havent used it yet due to axel trouble... and i hate that i might have just screwed myself out of $225 on a tranny that i busted before i used it. please tell me some good news about getting this fixed? although this is probably a 1st? thanks
Old May 20, 2003 | 07:48 PM
vladd's Avatar
tranny case is made out of aluminum.
Old May 20, 2003 | 07:56 PM
Default Re: transmission metal type. (civicdxtyper)
figured... so cant be welded up....thanks
Old May 20, 2003 | 09:03 PM
vladd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC Beast &raquo;</TD></TR><TR><TD CLASS="quote">figured... so cant be welded up....thanks</TD></TR></TABLE>
depends on where the crack is, it probably can still be welded up. however, if you have a professional shop do it, it'll probably not be worth the money. if you have a friend in an auto body class or something, they'll do it for free over there.
Old May 21, 2003 | 05:48 AM
yea, just have to try and find somebody that can weld aluminum. most people can only do steal.
prolifik22
Dec 22, 2007 11:00 AM
mach0
Oct 12, 2007 09:15 AM
lazie
Jun 22, 2005 07:32 PM
dc5 jared
11
Sep 2, 2004 06:47 AM
