Does Apexi VAFC reset it self after it looses its main power??
I just put in a VAFC jumper harness in my car because it is under warranty(like the skunk2 one where it goes between your main harness and the ECU).. And i was just wondering if i unplug the harness will i lose all my settings on my VAFC?? Does the VAFC have an internal battery backup??
Thanks
Greg
Thanks
Greg
what if you unplug it from the wire that are connected to the ecu wires?
what if you unplug the ecu?
will it reset doing either?
thanks
thanks
Smart little sucka ain't it.
<-----Should have gone Hondata for that price, and will be doing so.
The only way for it to loose the data, is to go to the initialize option...
I run the hondata S100, but it ended up costing me a lot more than my vafc, especially when it came time to tune it....
Later,
Aj
Later,
Aj
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeR 599 »</TD></TR><TR><TD CLASS="quote">what if you unplug it from the wire that are connected to the ecu wires?
thanks
It will never reset unless you make it reset.
You can always take out the vafc when you leave the car.
thanks
</TD></TR></TABLE>It will never reset unless you make it reset.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY »</TD></TR><TR><TD CLASS="quote">
You can always take out the vafc when you leave the car. </TD></TR></TABLE>
thanks, that's the plan
a little extra security never hurt
</TD></TR></TABLE>a little extra security never hurt
