upper mount
Old May 20, 2003 | 02:57 PM
ZUL8R's Avatar
Default upper mount
I tried to get the upper mount out of my 98 civic but failed,,, took the 3 bolts out, the top nut, and jacked up on the lower mount and the whole car kept lifting.. what am i doing wrong???
Old May 20, 2003 | 03:54 PM
Motorhead
Guest
Posts: n/a
Default Re: upper mount (ZUL8R)
If your referring to the lower AC bracket mount then you need to remove it. It is bolted to the underside of the driver side framerail & prevents the engine from over torqueing. That bracket will not allow you to lift up on the engine without moving the whole car. Just look at all 5 mounts & you'll understand,if not then you shouldn't be working on cars.
Old May 20, 2003 | 03:57 PM
tonyxcom's Avatar
you need to disconnect the torque mount/ac bracket thing. That is what is lifting your car.
EDIT. Actually, just disconnet the bracket that is held on my two bolts that the top nut was on. The 2 bolts bolt it down to the bracket under the timing belt cover.
Old May 20, 2003 | 06:24 PM
hondachick81's Avatar
Default Re: upper mount (tonyXcom)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tonyXcom &raquo;</TD></TR><TR><TD CLASS="quote">EDIT. Actually, just disconnet the bracket that is held on my two bolts that the top nut was on. The 2 bolts bolt it down to the bracket under the timing belt cover.</TD></TR></TABLE>
yea....thats what we were gonna do but didn't have a big enough deep socket.
Just gonna take it to a friend and have him slap it on for me
This wouldn't be a problem if Honda hadn't broken it in the first place!!! argghh
joes-92
Apr 1, 2013 05:24 PM
mateo5046
Apr 14, 2008 01:04 PM
XkjeldorX
Jun 21, 2006 01:49 PM
.Radical_Edward.
Jun 9, 2006 08:11 PM
Boost2NA
Aug 19, 2002 02:56 AM
