Need Some Help and Advice w/ Gauge Sensor Placement
Old May 20, 2003 | 01:57 PM
NXSpoon's Avatar
Default Need Some Help and Advice w/ Gauge Sensor Placement
Hey guys, the car is a 99 Civic Si and the gauges are Greddy Air/Fuel and EGT.
Where is the best place for the Air/Fuel O2 sensor?? I am running a rechipped P28 OBD1, so I have a space available in my cat. converter that isn't being used. Will this work accurately?? Or should it be closer to the header??
Also, is an EGT gauge worth it on a NA car?? I see that the turbo guys swear by this, does it hold any value for us all-motor guys?? If so, where should the sensor be placed??
Thanks
Old May 20, 2003 | 02:21 PM
dfoxengr's Avatar
Default Re: Need Some Help and Advice w/ Gauge Sensor Placement (NXSpoon)
you tap the sending wire for the AF guage into your existing O2 sensor signal wire, (white) egt still does mean something for NA, and still place it in the 3rd runner of the header...
Old May 20, 2003 | 02:30 PM
NXSpoon's Avatar
Default Re: Need Some Help and Advice w/ Gauge Sensor Placement (hybridvteceg)
The Greddy comes with an O2 sensor; which would be more accurate?? Teeing into the factory sensor or using the Greddy one??
Re: the EGT sensor. So I would drill and tap into the #3 runner on my JDM 4-1 ITR header?? How far away from the head?? And what kind of temps should it read??
Old May 20, 2003 | 06:15 PM
dfoxengr's Avatar
if its a 4wire sensor, bosch stock style, narrowband, itll be the exact same reading...
6-8 inches from head
Homotor
Nov 20, 2006 06:42 PM
94dxt
Apr 22, 2004 10:35 AM
speedymon
Mar 2, 2004 02:33 PM
sleeper4dr
Oct 2, 2003 08:10 PM
CLICC916
Jun 25, 2002 01:20 PM
