B16a block with GSR head power????
Old May 20, 2003 | 12:59 PM
PUSHER's Avatar
Default B16a block with GSR head power????
Considering buying a swap, the guy says its a jdm B16a(SIR2) block with a gsr head(dunno if jdm or usdm). Would this produce less or more hp than a full b16a engine?
Old May 20, 2003 | 01:48 PM
poison's Avatar
Default Re: B16a block with GSR head power???? (PUSHER)
with a p72 head on a stock B16 block, that will yield a higher compression (I believe 10.4) than a PR3 head on a B16. So yes, it'll produce a little bit more power.
Old May 20, 2003 | 01:49 PM
gumbybum's Avatar
Default Re: B16a block with GSR head power???? (poison)
but the gsr head doesnt flow as well
Old May 20, 2003 | 01:56 PM
PUSHER's Avatar
I'm to lazy to find the graph, but they average the same flow rate(gsr is like .00000003 better) What I was mainly wondering about was the compression. Which poison has stated to be higher(Thanks). Any more opinions?
Old May 20, 2003 | 03:19 PM
ScottEK's Avatar
Default Post title cannot contain more than half capital letters. Please revise.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PUSHER &raquo;</TD></TR><TR><TD CLASS="quote">I'm to lazy to find the graph, but they average the same flow rate(gsr is like .00000003 better) What I was mainly wondering about was the compression. Which poison has stated to be higher(Thanks). Any more opinions?</TD></TR></TABLE>
Did you mean (b16 is like .0000003 better)? I remember seeing the flow charts and I remember the b16 head winning on both intake and exhaust side.
Old May 20, 2003 | 03:37 PM
PUSHER's Avatar
I remember seeing the flow charts and at different rpms both were better. Top end on the gsr was better, but when avereaged together, they were close... but gsr was barely ahead. Lets not get to off topic though =P
*Feel free to prove me wrong, I looked at it like 2 days ago but cant find the graph.
Old May 20, 2003 | 06:34 PM
ScottEK's Avatar
Default Re: ()
Ok well back to topic, the compression would be raised, what's the GSR head rev out to?
Old May 20, 2003 | 08:09 PM
tmekjian's Avatar
with the gsr head you are also getting the dual stage intake mani which is a plus
the b16/type r head doesnt have those secondaries i believe...
someone feel free to correct me
Old May 20, 2003 | 08:25 PM
PUSHER's Avatar
Default Re: (tmekjian)
I'm kind of confused, dont people put b16 heads on b18 blocks to raise compression? So wouldnt that mean the GSR head would lower compression? Thanks for the info guys.
Old May 20, 2003 | 08:27 PM
Newman's Avatar
New User
Default Re: () (beta13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gumbybum &raquo;</TD></TR><TR><TD CLASS="quote">but the gsr head doesnt flow as well</TD></TR></TABLE>
You make it sound like there's a world of a difference, when there's little at all that can even felt with the B16 head and GSR head. With the smaller cc's on the GSR head (minutely smaller), it'll yield approximately .21 more compression to the original B16 motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beta13 &raquo;</TD></TR><TR><TD CLASS="quote">Ok well back to topic, the compression would be raised, what's the GSR head rev out to?</TD></TR></TABLE>
It'll "rev out" to whatever you take it too but it's safe to keep it under 8200 rpms on the stock valve springs, retainers and LMAs.
Old May 24, 2003 | 12:03 AM
biassj's Avatar
Default Re: (Newman)
I think the airflow vary, because there are good eggs and bad eggs. The square style combustion chamber on GSR head will give you a higher compression ratio, thus giving more power throughout power band. I prefer a GSR head stock wise, and comes with better cams.
Old May 24, 2003 | 11:21 PM
Mentat Ghola's Avatar
Default Re: (biassj)
hmm....im putin a b16 head on my GSR block, so compression will be down .2? This means that displacement is slightly higher correct? ahh well, probably wont even feel the difference. THe butterflies on the GSR manifold are nice, but that manifold is so DAHM GAY!!!!!!!!!!!!! Cant wait to put that pretty little b16 IM on the motor.
newbie1
Jan 8, 2008 10:28 AM
b18sihatch
Apr 16, 2007 07:49 PM
dr@ke
Aug 29, 2006 12:48 PM
skittyscott
10
Dec 8, 2004 04:41 PM
EG6owner-T
Sep 8, 2002 12:37 PM
