How do you install the typ r style strut bar?
Old May 20, 2003 | 11:54 AM
Thrillhouse's Avatar
Default How do you install the typ r style strut bar?
There are two black plugs on the shock tower and i know they bolt into there but it did not come with any hardware. What kind of bolts should i use? Lock washers? regular washers? nylon threaded nuts? Thx
Old May 20, 2003 | 11:58 AM
sPaRk'iT's Avatar
Default Re: How do you install the typ r style strut bar? (Thrillhouse)
i used regular bolt/washers and it worked fine! go to like Home Depot.
Old May 20, 2003 | 12:04 PM
Default Re: How do you install the typ r style strut bar? (sPaRk'iT)
What size?
Old May 20, 2003 | 01:42 PM
99silverbullet's Avatar
I did the same, just found four of the same bolts that fit perfectly , they are probably about 1-1 1/2 inches long. works great.
Old May 20, 2003 | 04:21 PM
Lord Helmet's Avatar
Default Re: How do you install the typ r style strut bar? (99silverbullet)
at least get some grade 8 bolts, I wouldn't get anything less.
PreyStayShun
Suspension & Brakes
11
Mar 4, 2012 08:35 AM
vietfella
Feb 10, 2007 06:03 PM
92civeg
Jun 20, 2003 03:56 AM
Maverick77
Jan 20, 2003 08:46 PM
mipawi
Jan 8, 2003 10:48 AM
