timing retard question
Old May 20, 2003 | 10:29 AM
fredtoast's Avatar
Default timing retard question
I am getting a lot of black on the back of my car. I have a jrsc with just the JR MAP controller and BTC. I know that this set up runs rich, but I was wondering if retarding the timing keeps the exhaust valves open during compression. At max boost (8 psi) the timing is retarded about 6.4 degrees. Could this be why my exhaust is so dirty or is it just because my A/F is so rich. I am not burning any oil that I can tell.
Old May 20, 2003 | 11:19 AM
JimBlake's Avatar
Default Re: timing retard question (fredtoast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fredtoast &raquo;</TD></TR><TR><TD CLASS="quote">... I was wondering if retarding the timing keeps the exhaust valves open during compression. At max boost (8 psi) the timing is retarded about 6.4 degrees...</TD></TR></TABLE>
Is your exhaust camshaft timing retarded or is your ignition timing retarded? I bet it's ignition timing. That has nothing to do with keeping your exhaust valve open.
Old May 20, 2003 | 11:36 AM
fredtoast's Avatar
Default Re: timing retard question (JimBlake)
You're right. I never thought about that. The camshafts' timing to the crank have not been changed. The BTC only controls the ignition timing. Thanks.
93lsv_turbo
Apr 15, 2011 12:08 PM
spoolingb20
Apr 26, 2006 10:46 AM
xcountrirunr
Dec 1, 2004 08:57 AM
aron0903
Aug 4, 2004 12:34 AM
(__________)
Oct 1, 2002 12:18 PM
