race seat in a 92-95, who has one what to do about stock seat belt??
Old May 20, 2003 | 05:53 AM
zc911's Avatar
Default race seat in a 92-95, who has one what to do about stock seat belt??
If i put a Sparco seat in my 92 hatch. the stock seat belts are mounted on the seat. Is there holes int eh floor to mount the buckle? OR am i **** outta luck?
I do not what to you 4 or 5point harneses everyday
Thanks
Old May 20, 2003 | 06:42 AM
Russ713's Avatar
dAng!
Default Re: race seat in a 92-95, who has one what to do about stock seat belt?? (zc911)
if you will not be using the stock rails, remove the buckle from the stock rail, and place it on the aftermarket rail.
Old May 20, 2003 | 06:57 AM
zc911's Avatar
Default Re: race seat in a 92-95, who has one what to do about stock seat belt?? (Russ713)
cool thanks
wasn;t sure if that would work
Old May 20, 2003 | 07:44 AM
4drGSR's Avatar
yah, there should be a mounting area on the rail for your seat belt. The seat belt bucly is held in by one bolt on your factory seat.
Old May 20, 2003 | 08:47 AM
owen_the_soyboy's Avatar
Default Re: race seat in a 92-95, who has one what to do about stock seat belt?? (4drGSR)
S&Mracing guys have used the seatbelt buckle from the 1988-1991 civics because those bolt to the floor.
find one at a junkyard.
Old May 20, 2003 | 09:04 AM
zc911's Avatar
Default Re: race seat in a 92-95, who has one what to do about stock seat belt?? (owen_the_soyboy)
ahhh good idea i ahve a couple extra EF ones actaully
Old May 20, 2003 | 09:38 AM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
Eh, my seat bracket for my Sparco has a bracket for the stock seatbelt buckle, not that I use it...
Old May 20, 2003 | 09:40 AM
zc911's Avatar
Default Re: race seat in a 92-95, who has one what to do about stock seat belt?? (SkyeC)
i just hink it's a hassle to use 5 point harnesses ont he street. plus the coppers around here don;t like it
Old May 20, 2003 | 09:49 AM
JaeOne3345's Avatar
Look up the post from owen_the_soyboy on homemade sparco seat brackets:
https://honda-tech.com/zerothread?id=362733
I did, and I was able to retain my stock seatbelt, since i used the stock EG rails/sliders which have a space to bolt the buckle too.
here are pics from my install:
btw. not all sparco brackets have the provisions for the seatbelt. there are street and competition brackets. from what ive heard the street brackets take even longer to get than the competition brackets. the comp brackets with no provisions for the stock belt is what you usually see. but wedge makes some with the provisions available. i dont like the wedge bracket/slider combo cuz it makes the seat kinda high. with the stock eg rails im really low.
Old May 20, 2003 | 09:56 AM
nerces's Avatar
i have a sparco corsa in my hatch and i got all the sparco seat mounts it sits kinda high but thats ok im kinda short i have sparco 4-point camlocks in my hatch i dont realy like the stock seatbelts with a race seat
Old May 20, 2003 | 09:59 AM
JaeOne3345's Avatar
Default Re: race seat in a 92-95, who has one what to do about stock seat belt?? (nerces)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nerces &raquo;</TD></TR><TR><TD CLASS="quote">i have a sparco corsa in my hatch and i got all the sparco seat mounts it sits kinda high but thats ok im kinda short i have sparco 4-point camlocks in my hatch i dont realy like the stock seatbelts with a race seat</TD></TR></TABLE>
well id run harness all day long on the street too but i like to move around and reach for stuff, and i also do not have a roll bar/cage installed.
Old May 20, 2003 | 10:07 AM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
Default Re: race seat in a 92-95, who has one what to do about stock seat belt?? (JaeOne3345)
I don't like how the stock seatbelt feels in a raceseat so I either run 4 points on the street or the stock seat/seatbelt. It's only 4 bolts, takes 10m to swap seats.
Old May 20, 2003 | 10:30 AM
JaeOne3345's Avatar
syke, i know what u mean. some race seats i have sat in have such high bolstering that the stock seat belt rest on the bolstering and not the driver. i was afraid of this, but its not the case with the sprint amazingly.
Old May 20, 2003 | 11:20 AM
zc911's Avatar
great thanks for that link
islander27
Oct 2, 2004 01:09 PM
purplevtec
Mar 12, 2004 07:54 PM
REFLUX
Apr 22, 2003 02:04 PM
EKhatch
Feb 25, 2003 10:57 AM
TurboIntegra
Sep 4, 2001 10:47 PM
