D16Y7 Cams
Old May 20, 2003 | 05:51 AM
FifthGearOnline's Avatar
Default D16Y7 Cams
anyone make cams for my motor all i see are b-series, and d-series vtec cams, but no d-series non vtec
help a slow brotha out
Old May 20, 2003 | 06:47 AM
sohc_boy's Avatar
Default Re: D16Y7 Cams (FifthGearOnline)
jgenginedynamics, gude, and delta cams make a cam for the y7, exospeed is working on one for the y7 but it isn't ready yet, hopefully soon. chk http://www.dseries.org for info on the delta cam.
Old May 20, 2003 | 02:29 PM
Default Re: D16Y7 Cams (sohc_boy)
cool!!
Old May 20, 2003 | 07:03 PM
pornstarSR's Avatar
i am having the same issue...but i think i have the problem solved.....Crane makes a cam for the d16a6, from what i have looked at and how the cam is setup it should be able to bolt right up to our motors....
and its a new core, no REGRIND
i have yet to try it but i will soon
Old May 20, 2003 | 07:50 PM
ExospeedAMcrx's Avatar
Default Re: D16Y7 Cams (Jim Morrison)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jim Morrison &raquo;</TD></TR><TR><TD CLASS="quote">I think u could get a y8 head for the price of a brand new cam for your y7
If i were u i would get the y8 head first then save for a vtec cam
belives in SOHC power </TD></TR></TABLE>
Good point....
but in the meantime, we do have y7 cam available. only a Stage 2 though. but thats ok.. its good for allmotor, and turbo.
Super aggressive cams for allmotor are not available yet. and we most likely wont try some out in the future.
No cores right now but if you send yours to us, takes only 2 days to finish.
Wil
Old May 20, 2003 | 11:39 PM
Default Re: D16Y7 Cams (exospeedAMcrx)
yea i would just need a mild cam for daily driving. so i cant really send you my core
Old May 21, 2003 | 03:57 AM
sohc_boy's Avatar
what kind of results can be expected from the stage 2 cam from u guys (exospeed)? i'm gonna be searching for a y7 cam to send. also i was under the impression that the a6 cam was not a direct bolt in for the y7 head? or is it just like the z6 cam in a y8 head just off by about 5 deg, which can be tweked via a cam gear?
Old May 21, 2003 | 08:12 AM
we havent dynoed this spec yet. but the specs we designed it for is not for any SUper Drastice changes u know.. this stage2 spec will be in the range of 5-8hp gain to the wheels. y7 cam is totally diff from any other d16 cam. cant put in a6 cam in the y7 head.
Old May 21, 2003 | 08:42 AM
sohc_boy's Avatar
thats what i though, just replying to the post above, making sure no misinfo is given here. i forgot to ask but how much are u going to charge for a regrind?
Old May 21, 2003 | 02:14 PM
pornstarSR's Avatar
has anyone tried the a6 cam in a y7 head?
thats what i want to know, it doesnt really make sense that the z6 cam will fit in a y8 but not a a6 in a y7
Old May 21, 2003 | 02:28 PM
Default Re: D16Y7 Cams (pornstarSR)
read 2 posts up. no you can not put an A6 cam in a Y7
Old May 21, 2003 | 02:33 PM
pornstarSR's Avatar
thats not the point.....no one has told me even if it has been tried
Old May 21, 2003 | 08:40 PM
the A6 and the Y7 nonvtec heads are not the same design. the Y8 and Z6 are similar thats why its compatible.
Old May 22, 2003 | 10:20 AM
pornstarSR's Avatar
ok well tell me this can you put a a6 cam in a 92-95 dx head(dont know the engine code)
cause if you can do that which i think someone said on here once, and i can put a 92-95 cam in the y7 head which i know has been done cause i have seen it....then why not a6 direct to y7.....
im not trying to make people pissed off, i know certain things people think cant work but i want to know for a fact that someone has tried it and then tell me it doesnt work....and i want to know the reasons why it didnt work.
Old May 22, 2003 | 11:07 AM
sohc_boy's Avatar
i would say no, and i have never seen a 92-95 non vtec cam in a y7, i asked the same questions over a year ago on too's board and this one. the answer was no, and that was coming from mistabone. and from what i know the 92-95 non vtec head was the same as the a6's head (i'm pretty sure on this but not 100%). i'm not pissed or anything just don't wanna see any mis-info thats all. and your sure u didn't see a z6 cam in a y8 head. maybe u saw a z6 cam in a y7 head since the y7 head is based off of the y8 head i would imagine that the cam would fit.
Modified by sohc_boy at 3:43 PM 5/22/2003
Old May 22, 2003 | 11:21 AM
pornstarSR's Avatar
all i want is the Right information....some people on thsi board just answer from hearsay.....
so now i think im getting good info....thanks for all the input guys
jjohn170
May 26, 2010 08:23 AM
jack meholf
Dec 17, 2007 01:07 PM
killacam661
Aug 11, 2007 08:08 PM
phiquach
Feb 18, 2004 06:44 PM
DaNish
15
Sep 29, 2001 06:16 PM
