Blox Cam users please look here!
Old Dec 15, 2007 | 02:33 AM
jack meholf's Avatar
Default Blox Cam users please look here!
I was just wondering of anyone else's experience with Blox cams?
As I've read boosted hybrid has seen a few issues with them, i just want to know how many other people have had success or failures with them, please post how long you've used them, actual cams used and if you feel like it setup and #'s made with them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted hybrid &raquo;</TD></TR><TR><TD CLASS="quote">My experiences on several customers cars running Blox A and B cams have been the keyway cracking, as well as the whole end of the camshaft shearing off. The crack in the keyway would def. led to enough stress riser to allow the cam to shear around the cam gear. I have never had a single issue with skunk2 cams (b-series) in the past couple of years. I can say that they are NOT the same cams "relabled", as evident by the failures that i have seen.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted hybrid &raquo;</TD></TR><TR><TD CLASS="quote">3 cars that i have tuned had the keyway areas crack, one sheared the cam off at the cam gear. I know two other shops in the area that have had similar experiences, it cannot be isolated. Infact the Blox B cams that were removed from FR geoff's civic had a cracked keyway on the cam, and my personal CTR cams are in the engine now for testing. Needless to say, the Blox's are not going back into his engine. </TD></TR></TABLE>
From Tony1's skunk 2 Pro 1 vs ITR cam test, here:
https://honda-tech.com/zero...age=4
Old Dec 15, 2007 | 03:35 PM
No one using Blox cams???
Old Dec 15, 2007 | 03:43 PM
non-VTEC's Avatar
Default Re: (jack meholf)
blox type a's here........been running for 10 months or so......no issues yet........i didnt notice any cracking by the key way area...but then again i wasn't really looking either.
i suppose the next time i have the cams out i'll have a look.......but im happy with the performance with them.
17psi 420whp @8500rpm and still climbing
Old Dec 16, 2007 | 03:32 AM
RedZone's Avatar
Default Re: (non-VTEC)
Im using Blox B's and Im making 525whp @14lbs uncorrected and 511 SAE...9100rpm and still climbing......
on stock 92 GSR cams I was making 425....
I have had no problems with them and plan to do more test after the 1st of the year
Old Dec 16, 2007 | 02:57 PM
Default Re: (RedZone)
Thanks for the info RedZone I read your gsr vs blox thread and was very impressed
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedZone &raquo;</TD></TR><TR><TD CLASS="quote">Im using Blox B's and Im making 525whp @14lbs uncorrected and 511 SAE...9100rpm and still climbing......
I have had no problems with them and plan to do more test after the 1st of the year</TD></TR></TABLE>
Old Dec 16, 2007 | 03:33 PM
delslo93's Avatar
I have Blox pro 1 replica's...haven't had any issues yet but I have only had them in for about 500 miles. Make very good mid and high range power. I need to get it on the dyno for numbers.
Old Dec 17, 2007 | 01:07 PM
Outkast95LS's Avatar
Default Re: (delslo93)
I have some Blox Type B's on my set up... only put on about 200 miles on it though. However, I bought it used from a guy who put about 5000 miles on it. I inspected it before using it, and there was no abnormalities on the cams itself. However, I'll be sure to double check it after I get a tune and put on some boosted miles on it.
However, from the experiences of people I know who have run the Blox cams, they never heard of any issues from them. I think the situation with the person(s) seeing the keyway areas cracked are probably just a defected bunch. There have been issues with a lot of other companies with their products having issues. It doesn't necessarily mean all the products are defective though..
dirtyharryhatch
Oct 14, 2008 04:40 PM
rookshot06
Jul 18, 2008 06:25 AM
rorik
Sep 19, 2007 05:41 PM
Old_Honda
Jun 25, 2004 07:53 PM
lilxvtecxpwr
Apr 3, 2004 03:10 PM
