tranny problems on the way home last night....
Old May 20, 2003 | 01:10 AM
svtec's Avatar
L D E S
Default tranny problems on the way home last night....
so, i stop at the library to drop off some books and then i leave and as i am shifting into third i notice a grind.
i thought i was being lazy with the clutch, but then into 4th same thing.
WTH the tranny was fine a second ago and now its acting like poop.
i just did the tranny fluid a month ago with honda mtl and it has been smooth as hell.
it even feels notchy as hell when i'm at a standstill rowing the gears.
i'm speechless. 71k on the tranny (gsr) no synchro issues, original clutch.
any suggestions would be nice...
-andrew
Old May 20, 2003 | 02:38 AM
97hb's Avatar
Default Re: tranny problems on the way home last night.... (svtec)
Did you make sure the car was on level ground when filling it back up? I had a 5th gear grind because it was still on jack stands when I filled it back up.
Old May 20, 2003 | 09:42 AM
svtec's Avatar
L D E S
Default Re: tranny problems on the way home last night.... (97hb)
yes, it was in the garage, but i dont think it has anything to do with the fluid level. it has been flawless for the last month and then to have it go to hell is odd.
its almost like the clutch doesnt engage all the way.
Old May 20, 2003 | 10:10 AM
NSX Bob's Avatar
New User
Sounds like a clutch problem, not a tranny problem. You may need to replace it.
Old May 20, 2003 | 10:21 AM
sackdz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by svtec &raquo;</TD></TR><TR><TD CLASS="quote">
its almost like the clutch doesnt engage all the way.</TD></TR></TABLE>
Other way around, clutch isn't disengaging all the way. You need either a new disc or pp.
delsold16
Sep 22, 2004 07:19 AM
reeder321
12
Dec 31, 2003 07:29 AM
Proper
Apr 23, 2003 04:55 PM
1fastdc2
Nov 4, 2002 02:09 AM
phatintegra
12
Mar 20, 2002 05:37 PM
