h22 euro r iac wiring
Old May 20, 2003 | 12:42 AM
RaceTUNE's Avatar
Default h22 euro r iac wiring
I swapped a h22 euro into a 93 prelude. How do you wire up the iac? the 93 prelude is 2 pin, and the euro is 3 pin.
I am using the 94 h22 jdm obd1 ecu.
thanks.
Old May 20, 2003 | 06:02 AM
mugencl1's Avatar
You need a jdm ecu from Euro R to drive the 3-wire rotary type idle valve (RACV). Anyway the 3 pin are connect to ecu, +12v and ground. I can check the color code for you later when I look at my shop manual.
Old May 20, 2003 | 08:39 AM
2point6's Avatar
Default Re: h22 euro r iac wiring (RaceTUNE)
Here is a link to a post I made on my site. It shows how to modify the ATR manifold to use the stock IAB. Check it out if you like. You may have to register to view. I appologize if this is an inconvienience.
http://www.collectiveracing.ne...;t=87
RMPHILLI
Jan 8, 2007 06:45 PM
BillClinton
Mar 22, 2005 07:01 PM
OutlawCL
Mar 14, 2005 03:37 AM
B18A1-ED6
Oct 25, 2004 03:24 PM
hybrid901
May 18, 2003 07:15 AM
