h22 euro r iac wiring
I swapped a h22 euro into a 93 prelude. How do you wire up the iac? the 93 prelude is 2 pin, and the euro is 3 pin.
I am using the 94 h22 jdm obd1 ecu.
thanks.
thanks.
You need a jdm ecu from Euro R to drive the 3-wire rotary type idle valve (RACV). Anyway the 3 pin are connect to ecu, +12v and ground. I can check the color code for you later when I look at my shop manual.
Re: h22 euro r iac wiring (RaceTUNE)
Here is a link to a post I made on my site. It shows how to modify the ATR manifold to use the stock IAB. Check it out if you like. You may have to register to view. I appologize if this is an inconvienience.
http://www.collectiveracing.ne...;t=87
