how to tell what codes im throwing??
Old May 19, 2003 | 10:11 PM
bdicustoms's Avatar
Default how to tell what codes im throwing??
i have a 92 vx with a gen 2 b16. when i started it up for the first time my check engine light came on. how do i check what codes im throwing or what the problem is?
Old May 19, 2003 | 10:18 PM
GReddy SI's Avatar
Default Re: how to tell what codes im throwing?? (bdicustoms)
its near your ecu , u might need a paper clip
Old May 19, 2003 | 10:23 PM
bdicustoms's Avatar
Default Re: how to tell what codes im throwing?? (GReddy SI)
what? can you be more specific??
Old May 19, 2003 | 10:24 PM
domestik2k's Avatar
get a scanner....... it will tell u what dtc's are getting thrown.
Old May 19, 2003 | 10:30 PM
GTlvr82's Avatar
its a liitle pin connector that you bend the paper clip into both sides. Your car needs to be on but not running so that when you open the door you don't get the dinging sound. When you put the clip in your CEL will blink. Short and Long blinks...write down how many and post it up here.
Old May 19, 2003 | 10:31 PM
domestik2k's Avatar
nevermind on my post there........ im tired and thinkin bout the wrong thing
Old May 19, 2003 | 10:32 PM
HATCHMO92's Avatar
he's got it , but to add more to it . look under the dash at the far right and you'll see the plugs for the ecu theirs one that is in a dead plug . just pull that one out and put the jumper in that
Old May 19, 2003 | 11:34 PM
IEATLINT's Avatar
Default Re: (HATCHMO92)
i know there is a site that lists all the codes also...don't know what it is though, sorry. search should find it, good luck
blumpfish
Apr 20, 2006 10:28 AM
Schaz
Nov 5, 2004 11:06 PM
beeroh
Sep 24, 2004 08:16 AM
Dragger817
Aug 18, 2002 12:46 PM
94ludesi
Oct 24, 2001 01:52 AM
