2 things found a very small spring in oil pan an what is the Torque settings on rods on crank shaft?
Old May 19, 2003 | 10:00 PM
gulf imports
Guest
Posts: n/a
Default 2 things found a very small spring in oil pan an what is the Torque settings on rods on crank shaft?
2 things found a very small spring {about an inch} in oil pan/ plus metal shaveings looks like copper? what is the Torque settings on rods on crank shaft? h23a1 94 si? i pulled my motor high rev motor is knockin spun berning on 3 number rod its very lose! im puting all new berning in it today, i need to know the Torque setting on the rods on the crank shaft?
help me asap!
Old May 19, 2003 | 10:22 PM
ludesleep's Avatar
Default Re: 2 things found a very small spring in oil pan an what is the Torque settings on rods on crank sh
34lbs-ft
Old May 19, 2003 | 10:25 PM
gulf imports
Guest
Posts: n/a
thx check pm!
Old May 20, 2003 | 02:29 PM
gulf imports
Guest
Posts: n/a
Default !@
its not the rod berning mother ******!! what the **** is it
Old May 20, 2003 | 02:33 PM
ludesleep's Avatar
Default Re: !@ (gulf imports)
could be a main bearing
Old May 20, 2003 | 11:13 PM
gulf imports
Guest
Posts: n/a
Default Re: !@ (ludesleep)
i could not get the ****** oil thing off!
antonio.b
Aug 14, 2013 06:08 PM
phaphon
Oct 15, 2012 07:05 AM
sixtodc2
Dec 17, 2007 11:36 PM
turbo boost
Jan 22, 2007 09:45 PM
allmotorgsrcivic
11
Jan 14, 2007 11:51 AM
