whats the worst that could happen
i think that i have a blown head gasket it only smokes when the car is warmed up whats the worst that could happen if i drve on it and will the head gasket that i have in my 1.5 std work in my 1.6 si both are 91 and how hard is it to replace
the head gaskets are the same... but don't re-use a used head gasket. You'll be in for more headaches than what it's worth to just get a new one.
and the worst that can happen.... Engine go boom!
More likely to happen.... warped head.
ya a seized engine, bent valves, warped head, just go to honda and pick up a headgasket for a d16y8 motor and slap it on and your done
Even if you cannot afford a head gasket from the honda dealer at least get one from your local autozone or oreilly's. Cause with a blown head gasket you can get water mixed in your oil wich will cause really bad lubrication and u can seize your engine, spin rod bearings etc. I would stop driving it until you get a new headgasket.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicBoyZC »</TD></TR><TR><TD CLASS="quote">Even if you cannot afford a head gasket from the honda dealer at least get one from your local autozone or oreilly's. Cause with a blown head gasket you can get water mixed in your oil wich will cause really bad lubrication and u can seize your engine, spin rod bearings etc. I would stop driving it until you get a new headgasket.</TD></TR></TABLE>
around here (socal) i called the dealership for a Y8 headgasket and it was only like 30 bucks or something like that
LSteggyguy
20
Dec 2, 2017 04:49 PM
