Removing upper ball joint
Old May 19, 2003 | 08:03 PM
speedsohc93's Avatar
Default Removing upper ball joint
i lost my Haynes manual. does anyone know if the uppper ball joint on a 93 is pressed into the control arm? how hard is it to remove?? i plan on buying the SPC camber kit, but according to their site, the ball joint is pressed on. is this really true?
Old May 19, 2003 | 09:11 PM
Accord94DX's Avatar
Default Re: Removing upper ball joint (speedsohc93)
correct. it is pressed on.
Old May 20, 2003 | 12:59 AM
GimpyAccord's Avatar
Default Re: Removing upper ball joint (Accord94DX)
the upper balljoint is unservicable short of replacing boots. to replace you must replace the upper control arm (about 120 dollars)
Old May 20, 2003 | 08:29 AM
GZERO's Avatar
Default Re: Removing upper ball joint (GimpyAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GimpyAccord &raquo;</TD></TR><TR><TD CLASS="quote">the upper balljoint is unservicable short of replacing boots. to replace you must replace the upper control arm (about 120 dollars)</TD></TR></TABLE>
whyS0serious
Suspension & Brakes
Apr 17, 2018 12:45 PM
G2_Fella
24
Jun 16, 2009 03:20 PM
Gsir8
Jun 21, 2007 06:48 AM
digitalayon
Suspension & Brakes
Dec 19, 2005 05:26 PM
DaChoZn1
Sep 18, 2005 03:34 PM
