i took yalls advice
i followed every ones advice and i'm purchasing a 91 civic si 2dr hatch it has minor body damage for an accident the only thing that worries me is that he said that he had the head rebuilt but now he said whe it heats up and runs that it smokesout the exaust and the radiator over flows into the resivior any idea what could cause this
Modified by bigdogmaley at 5:32 AM 5/20/2003
i never worked on imports before and never personally did a head gasket on a domestic but i heard its a pian in the a!! AND VERY EXPENSIVE if have some else do it is it the same for this modle honda and whats the worst to happen if i drive on it
he blew the HG and it prolly needs a thermostat. who cares. I have a d15 for sale that will bolt right in. 150+ shippin. runs strong. I mean the d16s/d15s are so easy to come by! dont worry bout it, just put in a new HG or put in my motor
Blaze
Blaze
is getting b18 from a junk yard a good idea how much do they run and they will swap right into my 91 si right what else do i need to change and what is the diffrence between b16a or d16s and the diffrent numbers and how do i find out what i have i know i ask alot of questions but i'm just trying to learn new at this
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MONSTERZC »</TD></TR><TR><TD CLASS="quote">he blew the headgastet</TD></TR></TABLE>
Go to hasport.com for swap info, also check out my site. A b16a swap is basically the same swap as a b18a, minus the vtec wiring. Hope this helped. Ryan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by new_to_hondas »</TD></TR><TR><TD CLASS="quote">is getting b18 from a junk yard a good idea how much do they run and they will swap right into my 91 si right what else do i need to change and what is the diffrence between b16a or d16s and the diffrent numbers and how do i find out what i have i know i ask alot of questions but i'm just trying to learn new at this </TD></TR></TABLE>
99.999% sure that is the cause. change the head gasket and the temp sensor and you are good to go.
d series motors= 1.5-1.6 sohc motors w or w/0 vtec
b series motors=1.6-2.0 dohc motors w or w/o vtec
for and d series swap u need a d series tranny
for any b series swap u need a b series tranny
also ur car would need a mount kit different axles different tranny, ecu, and different shift linkages to put any b series motor in ur car when shoppin look for a cable tranny not hydro
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blaze45 »</TD></TR><TR><TD CLASS="quote">he blew the HG and it prolly needs a thermostat. who cares. I have a d15 for sale that will bolt right in. 150+ shippin. runs strong. I mean the d16s/d15s are so easy to come by! dont worry bout it, just put in a new HG or put in my motor
Blaze</TD></TR></TABLE>
The d15 will bolt in but he has mpfi and the d15 has dpfi so unless he wants to do the conv on the motor id jus look for another a6 or swap to something better.
Stock motors are kinda gutlas anyway. It is just a reason to do a swap in it. When I bought my efs, I got the car and a swap the first week. Car on monday motor swap on friday. He did blow the head gasket by the way but I'm sure you know that by now. It's not stock motors are junk or anything, but if ya wanna fly, gotta buy.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blah13 »</TD></TR><TR><TD CLASS="quote">
The d15 will bolt in but he has mpfi and the d15 has dpfi so unless he wants to do the conv on the motor id jus look for another a6 or swap to something better.</TD></TR></TABLE>
He could run the D16 intake manifold on the D15 couldn't he? I have a friend who did that I beleive he just swapped manifolds I don't beleive he swapped heads. Then you can D15MPFI.
carracr625
May 12, 2009 02:33 PM
budomove
Dec 4, 2006 07:36 AM
91CRXSiSWAPS
Jun 26, 2004 04:04 PM
