why does it smoke?
Old May 19, 2003 | 07:01 PM
NVMYSi's Avatar
Default why does it smoke?
OK, here is the situation. Fresh built R motor with around 1200 miles on it. Under heavy acceleration when I hit 5K and up rpm I start to blow smoke. Light color, maybe light blue. Not realy heavy but definetly noticable. I just got the car tuned so that eliminated the running rich, and I checked the plugs and they look good. I am wondering if it could be possibly a bad valve seal or maybe a ring didn't seat correct. Anybody have any ideas?
Old May 20, 2003 | 06:35 AM
NVMYSi's Avatar
Default Re: why does it smoke? (NVMYSi)
hmmmm, i stumped everybody?
Old May 20, 2003 | 06:51 AM
Russ713's Avatar
dAng!
get a leak down test performed.
Old May 20, 2003 | 09:20 AM
brainwo's Avatar
New User
Default Re: why does it smoke? (Russ713)
Old May 20, 2003 | 09:37 AM
1_bad_EF's Avatar
You didn't use stock bore pistons did you? If so, you have to much cylinder to piston clearance. Its almost guaranteed that an engine will smoke then.]
Tell everything you know about the rebuild also.
if you did not seat the ring within the first 50 of so miles that would cause the smoke too.
Normal break in procedure: 2nd gear 2k-5k and let revs come back to 2k. repeat
over and over
hailchristian
42
May 30, 2008 04:20 PM
prettylew
45
Dec 16, 2007 06:48 PM
Sassafrass
May 19, 2006 04:47 AM
allm0torGSR
15
Jul 27, 2004 10:08 PM
GENERAL LEE
Nov 16, 2003 09:50 AM
