whats a good range of possible hp from a slightly built d16 turbo?
Old May 19, 2003 | 06:44 PM
mugensport9's Avatar
Default whats a good range of possible hp from a slightly built d16 turbo?
d16y6
supra piston/b16 rod hybrid and block gurard.
i hear about 240 at about 14-15lbs boost. and the motor is safe to run up to 18. so on the nights when i go to the track and boost 18psi what kind of power should i expect?
Old May 19, 2003 | 07:00 PM
tdaccord's Avatar
Default Re: whats a good range of possible hp from a slightly built d16 turbo? (mugensport9)
i haven't heard of the supra piston. what model supra do you use? i would like more info on this.
and which engine is the y6?
Old May 19, 2003 | 08:04 PM
Default Re: whats a good range of possible hp from a slightly built d16 turbo? (tdaccord)
reply talk to 'turbo panda' he is the one i am buying the pistons and rods off of. the supra pistons fit d16's and they can handle 14-18psi daily. also this comes with a set of b16 rods, this is a custom set-up that people do in asia. it seems to be relativly cheap and works well. turbo panda is located in thai land. the pistons and rods are the best bang for the buck in my opinion.
Old May 19, 2003 | 08:23 PM
WuShu's Avatar
New User
dude your asking how much hp you will get out of a custom setup, it is impossible to answer your question. Only way youd get an answer is if someone was running that same setup and even then there are too many variables to make 2 setups similar. i would ask turbo panda what type of numbers ppl using his pistons are pushing.
Old May 20, 2003 | 04:11 PM
Default Re: whats a good range of possible hp from a slightly built d16 turbo? (WuShu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WuShu &raquo;</TD></TR><TR><TD CLASS="quote">dude your asking how much hp you will get out of a custom setup, it is impossible to answer your question. Only way youd get an answer is if someone was running that same setup and even then there are too many variables to make 2 setups similar. i would ask turbo panda what type of numbers ppl using his pistons are pushing. </TD></TR></TABLE>
yes, i understand that, thats why i asked range. its obvious that it is impossible to get an exact number. instead of comming in here and being an *** just to add some posts to your name, read the title.
<U>RANGE</U>
Old May 20, 2003 | 04:26 PM
WuShu's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugensport9 &raquo;</TD></TR><TR><TD CLASS="quote">
<U>RANGE</U> </TD></TR></TABLE>
of every single post I have ever read like this, this is the first one I didnt lock, main reason was I figured hey ill be nice and let the post go by showing ppl that if this is not a place to get opinions. You however have made it obvious you knew what your answer would be, so guess what, you get a nice fat lock. you want opinions do a search.
farcie123
Dec 1, 2014 03:39 AM
rylflsh1806
May 19, 2009 02:33 PM
model x
Nov 28, 2005 02:19 AM
sleeperHatch
May 21, 2005 11:14 AM
mugensport9
May 19, 2003 08:01 PM
