Ignition Wires, which perform best?
Old May 19, 2003 | 06:32 PM
pcorad's Avatar
Default Ignition Wires, which perform best?
I read the following on GRM http://grassrootsmotorsports.com under Tech Info, and Stock Tips. Any truth to this? Anyone tested a stock motor with stock wires vs. aftermarket wires on a dyno?
Ignition Wires
"Ignition wires are free in Solo's Stock class: the rules state they may be replaced with pieces of any origin. From the data we've collected, it's a worthwhile modification.
Replacing the brand-new stock wires on our BMW 318ti project car with a set from Magnecor gave us around two additional horsepower at the drive wheels, while our Neon got a three-horse bump when we replaced the stock wires with some hot ones. Installing a set of performance wires on our Honda CRX project car didn't unleash any more power, but the new horsepower curve was both smoother and no longer fell away at the top end.
In testing with a variety of cars at our Dyno Day events, we've found that nearly every vehicle benefited from having the stock wires replaced with quality aftermarket pieces from companies like Magnecor or Ignition Equipment. We found consistent power jumps in the two- to three-percent range; that's pretty significant. Plus, performance spark plug wires don't cost that much. Figure $50 to $150 depending on the application."
Old May 19, 2003 | 06:35 PM
Hybrid ctr's Avatar
Default Re: Ignition Wires, which perform best? (pcorad)
Stock NGK
Old May 19, 2003 | 06:38 PM
typeR 507's Avatar
MSD
Old May 19, 2003 | 06:50 PM
vtec.dc2's Avatar
stock motor - use stock wires, and they should be good for 45-60K miles if not more. plug wires/grounding kits and other similar products are there to possibly improve ride quality, not to increase hp.. more effort/time/money is needed to get some real hp gains..
i've used stock sumitomo wires with n/a bolt-ons, and probably going to use it with turbo kit.
Old May 19, 2003 | 06:58 PM
BlueR's Avatar
Default Re: Ignition Wires, which perform best? (Hybrid ctr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid ctr &raquo;</TD></TR><TR><TD CLASS="quote">Stock NGK </TD></TR></TABLE>
these also have the best fitment
Old May 19, 2003 | 06:59 PM
GokuSSJ4's Avatar
Default Re: Ignition Wires, which perform best? (BlueR)
Stock
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR &raquo;</TD></TR><TR><TD CLASS="quote">
these also have the best fitment </TD></TR></TABLE>
Old May 19, 2003 | 08:41 PM
ITR#132's Avatar
Default Re: Ignition Wires, which perform best? (Spoon1)
Which year did NGK come as stock? Whats the part number for the stock Honda NGKs?
GQ 05YellowEVO8
Apr 7, 2005 05:52 PM
turbolshatch
Apr 19, 2004 04:52 PM
Z7
Feb 10, 2003 11:15 AM
4gvtec
May 13, 2002 08:44 PM
