when installing new cam shaft can i use regular oil to lube it?
Old May 19, 2003 | 06:02 PM
civicracer1993's Avatar
Default when installing new cam shaft can i use regular oil to lube it?
i hear u should use cam shaft lube but will regular oil work? its a SOHC z6 head.
Old May 19, 2003 | 06:07 PM
KoRE's Avatar
Default Re: when installing new cam shaft can i use regular oil to lube it? (civicracer1993)
You can but i would use the cam lube to be safer.
when i installed gsr cams into the b16 i used oil when i did my ef-1 cams i used cam lube, mainly because it came with it. lol if it didn't come with it i would probbaly have used oil.
but i'm assuming they make cam lube for a reason, so i would say use that its not expensive to buy some .... good luck
tundra2000
May 24, 2011 04:07 PM
Creator
Feb 16, 2008 03:44 PM
an2ny888
Feb 20, 2005 06:06 AM
toooslow
Apr 10, 2003 11:41 AM
1.8Tities
Sep 25, 2002 04:47 PM
