ARP head studs...
Old Jul 11, 2001 | 07:37 AM
bigTom's Avatar
Default ARP head studs...
an ls block with a gsr head on it... which bolts to use... the b18c bolts or the b18a bolts?
Old Jul 11, 2001 | 07:54 AM
Rory Breaker's Avatar
Default Re: ARP head studs... (4dr-gsr)
I would assume B18c...correct me if im wrong.
Old Jul 11, 2001 | 09:45 AM
C-speed's Avatar
Default Re: ARP head studs... (newgsrdriver)
you *MUST* use B18C studs/bolts. The B16, B18A/B etc bolts are not long enough and you will eventually blow the head right off the block. I've seen it happen.
HTH
oranginal
May 2, 2006 11:14 AM
FunIntegras
Nov 18, 2005 12:28 AM
Riceintegrars
May 24, 2005 10:45 AM
D.Dappa
Mar 11, 2005 07:53 PM
