SMC, JRSC, and Stock FPR ???
Old May 19, 2003 | 03:56 PM
keebler65's Avatar
Default SMC, JRSC, and Stock FPR ???
i just installed a JRSC and am running the SMC+ for fueling. i connected the stock FPR to the JR mani, so it is seeing boost. is this incorrect? should i hook it up before the blower instead? the reason i ask is because tuning it this way has been odd. i found i have to cut more fuel for 6psi than i ever needed to stock. i'm running DSM 450's and i have the fuel cut by 50% from 5k-8krpm. i'd appreciate if someone could clear this up for me.
thanks
Old May 19, 2003 | 05:12 PM
jabroni95gsr's Avatar
Default Re: SMC, JRSC, and Stock FPR ??? (keebler65)
sorry man, can't help you on this one. bump for you.
Old May 19, 2003 | 05:29 PM
sharkcohen's Avatar
You have it connected correctly. Are you running the stock fuel pump?
Old May 19, 2003 | 06:10 PM
keebler65's Avatar
Default Re: SMC, JRSC, and Stock FPR ??? (sharkcohen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sharkcohen &raquo;</TD></TR><TR><TD CLASS="quote">You have it connected correctly. Are you running the stock fuel pump?</TD></TR></TABLE>
yes the stock fuel pump. i just found it odd that i would have to cut that much fuel for the 450cc injectors. well it works fine; i just hope its reliable, etc.
Old May 19, 2003 | 06:20 PM
sharkcohen's Avatar
Heh, think of it as plenty of tuning room for increasing the boost
Old May 24, 2003 | 10:45 AM
Westsideboy's Avatar
I believe that you will need to run a vacuum line from your intake manifold back to your MAP sensor. The stock mounting position of your MAP sensor will not allow the sensor to see boost as it is mounted near the TB and where it pulls the reading from, it'll only see vacuum.
Old May 24, 2003 | 11:29 AM
keebler65's Avatar
Default Re: SMC, JRSC, and Stock FPR ??? (Westsideboy)
yeah i already did that. thanks though. anyways since this moved ttt, it seems to be working fine with the high levels of fuel cut.
Old May 30, 2003 | 09:47 AM
Well, think about it this way...
Your stock injectors are 240cc's. Your new DSM 450cc injectors are about twice as big as your stock. SOoo...450 / 2 = 225cc's or so... so that'll be like stock... If I'm correct, you can use an FPR to raise or lower fuel pressure if it's still not enough cut.
I'll be doing this mod soon, as soon as I get my car e-tested. I'm not sure if this set up passes emissions.
oacrep1
Feb 6, 2006 07:34 AM
escape2me
Sep 30, 2005 07:29 AM
stockgreencivic
Nov 3, 2003 07:44 AM
Pfieff
Jun 30, 2003 02:30 PM
DeDonDeRosa
Dec 16, 2002 11:19 AM
