n/a sux.....j/k gals, here comes my new dyno plots
Old May 19, 2003 | 01:11 PM
austrian type-R's Avatar
Default n/a sux.....j/k gals, here comes my new dyno plots
The most beautiful thing IMO: With same boost level I have 50bhp more than with my old setup on dyno 14 month ago. That means I have NOW with 1.2 Bar boost 423 bhp VERSUS 375bhp before. 1.2-1.3 Bar is daily driven and no problem for the engine
Here is the old dyno plot with 1.55 Bar and manual boost controller
430bhp and 430 newtonmeter
look at 5000rpm, there was spoole time. I think reason for low spool up time is DRAG logstyle manifold and manual boost controller
I have changed following thinkgs since last dyno session:
440cc to 720cc injectors
Meng equal length tubular manifold
removed restrictor from exhaust
electronic boost controller.
Cat stripped
here are the plots with 1.2 Bar from todays session:
423bhp, 477 Newtonmeters
Look at the drivetain lost! 82bhp lost in drive train at 280kph (173mph). Thats about double drivetrain lost from 240kph to 280kph. I have 40hp drivetrain lost at 240kph, but 82hp at 480kpH. I used 215/65/15, since I had to low ground clearence for the dyno rolls.
much more awesome, the spool up time with same Turbo from DRAG III kit.....it is nearly 1000rpm better than before. Realy ****** awesome is I have at 1.2 Bar boost 477 Newtonmeter instead 430nm at 1.55 Bar before. I think it is the reason of ebc and manifold + removed restrictor
HERE comes the plot with 1.65 bar overboost ...too bad it blows the tire at 280kmh on the dyno rolls, but our luck nothing happand. extremely is the lost in drivetrein power sine the tire braked the rolls very mich
480bhp is that....about 415 whp
There is not more newtonmeter than with dyborun on 1.2 Bar, cause I turned up the boost at about 7000rpm and most newtonmeter I have at 6000rpm.
Too bad I was not able to test out the Aquamist Waterinjection, cause of destroyed tire.
At least I am very happy with 50bhp more at same boost levels than before and 70nm more at lower boost level than before on higher boost numbers....spoll up time increased very much too.
PS: This is still with Turbonetics T3 63AR/T04e 54AR and 2.5inch dp.
Old May 19, 2003 | 01:20 PM
Casey's Avatar
Default Re: n/a sux.....j/k gals, here comes my new dyno plots (austrian type-R)
very impressive numbers i think you need a larger turbo, 3" dp and a sheetmetal intake manifold and youll be set
Old May 19, 2003 | 01:21 PM
Champ R's Avatar
Holy crap! When the boost really kicks in near 5k that must be insane.
Old May 19, 2003 | 01:25 PM
Project SSAP1's Avatar
Default Re: n/a sux.....j/k gals, here comes my new dyno plots (Casey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Casey &raquo;</TD></TR><TR><TD CLASS="quote">very impressive numbers i think you need a larger turbo, 3" dp and a sheetmetal intake manifold and youll be set </TD></TR></TABLE>
yes it is time for a bigger turbo!! and 3" DP
Old May 19, 2003 | 01:38 PM
sil's Avatar
sil
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by austrian type-R &raquo;</TD></TR><TR><TD CLASS="quote">1.2-1.3 Bar is daily driven and no problem for the engine
Old May 19, 2003 | 01:42 PM
DutchITR1689's Avatar
Nice numbers, I wonder how long the engine will last......
You blew a tire at 280km/h on a dyno? OMG
Old May 19, 2003 | 01:45 PM
Default Re: n/a sux.....j/k gals, here comes my new dyno plots (DutchITR1689)
engine will last forever :knockonwood:
Yeah, it smoked blue and black and I had all the damn rubber everywhere on the car and on the flor. LOL. The tire was just a bit too big for the fenders. It rubbed on inner fender, cause at that high speed the tire gets more volume that on low speed due gravitation. We was not able to drive in 4th, cause the tires spinned on the dyno rolls.
Old May 19, 2003 | 01:49 PM
What kind of tires were those? W speed rated? Or Y?
Old May 19, 2003 | 01:56 PM
ZR for more than 300kph. I guess the tire broke and then it rubbed on the inner fender at some metall.
Old May 19, 2003 | 02:00 PM
baonest1's Avatar
can anyone convert those #s to US. or are they about equal??
Old May 19, 2003 | 02:07 PM
Default Re: n/a sux.....j/k gals, here comes my new dyno plots (baonest)
are about equal. 1 KW = 1.36hp
Old May 19, 2003 | 02:42 PM
sil's Avatar
sil
1 bar == 14.50377 PSI
Old May 19, 2003 | 03:02 PM
GettaluvR's Avatar
New User
Default Re: n/a sux.....j/k gals, here comes my new dyno plots (sil)
man what else can i say...
M5 can kiss your ***..... type-r with nearly 500 hp just insane...........................
Old May 19, 2003 | 03:56 PM
pinota's Avatar
Default Re: n/a sux.....j/k gals, here comes my new dyno plots (GettaluvR)
Nice !!!
Old May 19, 2003 | 03:58 PM
RTW DC2R's Avatar
Default Re: n/a sux.....j/k gals, here comes my new dyno plots (pinota)
that hurts, it really does.
Ryan, who spent way too much money on NA mods and will b00st from here on out.
Old May 19, 2003 | 04:08 PM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: n/a sux.....j/k gals, here comes my new dyno plots (RTW DC2)
b00st ownz
Splat, who is itching to upgrade the 220whp Turbo Pig now
Old May 19, 2003 | 04:13 PM
RaVAGE00's Avatar
New User
man..... that is freakin crazy....
That thing is a pimpen stang, vette, wrx, ferrari, lambo, viper, porsche killa!
Old May 19, 2003 | 04:15 PM
disordeR's Avatar
Default Re: n/a sux.....j/k gals, here comes my new dyno plots (RaVAGE00)
that's okay power...
j/k VERY nice.
Old May 19, 2003 | 04:38 PM
NA gs-R 05 C
Guest
Posts: n/a
damn, those are sum good #'s.
Old May 19, 2003 | 05:56 PM
PiYoImuT's Avatar
Default Re: n/a sux.....j/k gals, here comes my new dyno plots (zyg)
when my R is as old as Ed's then I will prolly Boost-in too..
(by that time I should have enough $ for new engine anyway)
LOL
Nice power..
Old May 19, 2003 | 07:16 PM
JUN JDM's Avatar
good numbers!
Old May 19, 2003 | 07:26 PM
Kelvin96GSR's Avatar
25 Year Member
Default Re: (JUN JDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUN JDM &raquo;</TD></TR><TR><TD CLASS="quote">good numbers! </TD></TR></TABLE>
good numbers??? More like insane numbers!!!
Old May 19, 2003 | 07:41 PM
Black R's Avatar
25 Year Member
What sort of internals?
Old May 19, 2003 | 11:54 PM
Default Re: n/a sux.....j/k gals, here comes my new dyno plots (Black R)
DRAG III turbo kit
Meng Tubular equal length manifold
Turbo is water cooled
Haltech e6k ECU
Eagle rods
JE pro series pistons 9:1
ARP headstuds
Crower valve springs & retainers
AEM fpr
Walbro fuel pump (from JRSC kit)
RC 720cc injectors
Clutchnet stage 2
3" Thermal RD exhaust
3" Carsound Cat (stripped)
17row oil cooler
JR thermostat
5 Greddy gauges
Apexi AVC-R
Greddy profec B
Tial wastegate 35mm
Open dumptube from wg
Old May 19, 2003 | 11:56 PM
B2FiNiTY's Avatar
jeez... that's impressive.
