yupieeeee, new awesome dyno numbers for me!
Old May 19, 2003 | 01:09 PM
austrian type-R's Avatar
Default yupieeeee, new awesome dyno numbers for me!
The most beautiful thing IMO: With same boost level I have 50bhp more than with my old setup on dyno 14 month ago. That means I have NOW with 1.2 Bar boost 423 bhp VERSUS 375bhp before. 1.2-1.3 Bar is daily driven and no problem for the engine
Here is the old dyno plot with 1.55 Bar and manual boost controller
430bhp and 430 newtonmeter
look at 5000rpm, there was spoole time. I think reason for low spool up time is DRAG logstyle manifold and manual boost controller
I have changed following thinkgs since last dyno session:
440cc to 720cc injectors
Meng equal length tubular manifold
removed restrictor from exhaust
electronic boost controller.
Cat stripped
here are the plots with 1.2 Bar from todays session:
423bhp, 477 Newtonmeters
Look at the drivetain lost! 82bhp lost in drive train at 280kph (173mph). Thats about double drivetrain lost from 240kph to 280kph. I have 40hp drivetrain lost at 240kph, but 82hp at 480kpH. I used 215/65/15, since I had to low ground clearence for the dyno rolls.
much more awesome, the spool up time with same Turbo from DRAG III kit.....it is nearly 1000rpm better than before. Realy ****** awesome is I have at 1.2 Bar boost 477 Newtonmeter instead 430nm at 1.55 Bar before. I think it is the reason of ebc and manifold + removed restrictor
HERE comes the plot with 1.65 bar overboost ...too bad it blows the tire at 280kmh on the dyno rolls, but our luck nothing happand. extremely is the lost in drivetrein power sine the tire braked the rolls very mich
480bhp is that....about 415 whp
There is not more newtonmeter than with dyborun on 1.2 Bar, cause I turned up the boost at about 7000rpm and most newtonmeter I have at 6000rpm.
Too bad I was not able to test out the Aquamist Waterinjection, cause of destroyed tire.
At least I am very happy with 50bhp more at same boost levels than before and 70nm more at lower boost level than before on higher boost numbers....spoll up time increased very much too.
PS: This is still with Turbonetics T3 63AR/T04e 54AR and 2.5inch dp.
Old May 19, 2003 | 01:29 PM
.nate's Avatar
very nice! you should benefit a lot from a bigger dp.
Old May 19, 2003 | 01:31 PM
BLKCRX's Avatar
Default Re: (v01d)
seems like great differences from just changing the exhaust mainfold... from log to full length.. which mainfold did ya go with ??? i soo want a equal length mainfold instead of my maxrev one.. but yeah can't afford it yet.... im going to work on traction next.. rather than more HP...
Regards James
Old May 19, 2003 | 01:49 PM
psileepR's Avatar
New User
Default Re:
I still love you vid on the track whoopin some ****!!!
Old May 19, 2003 | 02:35 PM
spark's Avatar
This is so awesome. I can clearly see now the avantages of equal length tube manifold.
So I guess the next step will be to put a 3 inchs downpipe ?
Old May 19, 2003 | 02:37 PM
Quick 200k Mile Motor's Avatar
Default Re: yupieeeee, new awesome dyno numbers for me! (austrian type-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">This is still with Turbonetics T3 63AR/T04e 54AR and 2.5inch dp.</TD></TR></TABLE>
awesome! what wheel trim on the compressor side and turbine side?
Old May 19, 2003 | 03:07 PM
jinxproof99's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by austrian type-R &raquo;</TD></TR><TR><TD CLASS="quote">The most beautiful thing IMO: With same boost level I have 50bhp more than with my old setup on dyno 14 month ago. That means I have NOW with 1.2 Bar boost 423 bhp VERSUS 375bhp before. 1.2-1.3 Bar is daily driven and no problem for the engine.</TD></TR></TABLE>
so whats that really mean??? in american this time.
nice numbers.
Old May 19, 2003 | 08:52 PM
SiRkid's Avatar
Default Re: yupieeeee, new awesome dyno numbers for me! (jinxproof99)
Old May 19, 2003 | 11:47 PM
Default Re: yupieeeee, new awesome dyno numbers for me! (SiRkid)
at 17.4 psi it hat 425 brutto horse power. Drive train lost at 150mph are 385whp and at 205mph 344whp. The 215/65/15 has lots of drivetrein lost and at that speed it is so much lost in drivetrain that on 150mph. Last year I had only 375bhp at 17.4psi.
At 23psi I have 480bhp = 440whp.
Not tuned cause of damaged tire. I need to get an 17inch rim fpr lower profile tire on the dyno.
Old May 20, 2003 | 01:05 AM
T-Blaze's Avatar
Woooo hold on a sec... Am I reading this correctly??? 205mph??? Isn't this the sickkk ITR trackday killah???
Those are some serious numbers and some mad amount of booost!!! That block must be bullet proof!!! It's a shame the tyres aren't.
BIG
Old May 20, 2003 | 01:08 AM
Default Re: yupieeeee, new awesome dyno numbers for me! (T-Blaze)
yeah that is my ITR: I have JDM 5th 0.787 with USDM final drive 4.400
Old May 20, 2003 | 01:41 AM
swlabhot's Avatar
I guess the 'big tyre' you're running also helped you to reach that speed but with the sacrifice of greater drivetrain loses.
Damn. to you. I'll be happy just to make 300whp on mine.
What forged internals did you use? Better still, whats your complete setup?
Old May 20, 2003 | 02:09 AM
Default Re: yupieeeee, new awesome dyno numbers for me! (swlabhot)
DRAG III turbo kit
Meng Tubular equal length manifold
Turbo is water cooled
Haltech e6k ECU
Eagle rods
JE pro series pistons 9:1
ARP headstuds
Crower valve springs & retainers
AEM fpr
Walbro fuel pump (from JRSC kit)
RC 720cc injectors
Clutchnet stage 2
3" Thermal RD exhaust
3" Carsound Cat (stripped)
17row oil cooler
JR thermostat
5 Greddy gauges
Apexi AVC-R
Greddy profec B
Tial wastegate 35mm
Open dumptube from wg
Old May 20, 2003 | 02:52 AM
T-Blaze's Avatar
Nice set up... Now I have something to aspire to...
Old May 20, 2003 | 04:21 AM
swlabhot's Avatar
nice setup u have there. What compression are u running?
Any more Mario vids
Old May 20, 2003 | 04:31 AM
Casey's Avatar
is the block sleeved? if not, props for 23psi on an unsleeved itr block
Old May 20, 2003 | 04:49 AM
TurboSedan's Avatar
New User
Wow, nice setup and sweet numbers.
Old May 20, 2003 | 06:03 AM
Default Re: yupieeeee, new awesome dyno numbers for me! (TurboSedan)
9.1:1 CR, stock sleeves.
Old May 20, 2003 | 06:55 AM
metal-x's Avatar
wow stock sleeves very impressive
Old May 20, 2003 | 11:25 AM
Dublocivic's Avatar
Or Austrailian would suffice. eheh. jk
nice numbers
Modified by Dublocivic at 5:29 PM 5/20/2003
Old May 20, 2003 | 11:38 AM
b18bturbo's Avatar
Default Re: yupieeeee, new awesome dyno numbers for me! (Dublocivic)
damn awesome number christian you should be happy as hell now...
Old May 20, 2003 | 12:25 PM
CzanSOHC's Avatar
Default Re: yupieeeee, new awesome dyno numbers for me! (b18bturbo)
very nice!
Old May 20, 2003 | 12:55 PM
khang77642's Avatar
daymm, awesome number . Now all we need is your next video.
Old May 20, 2003 | 01:57 PM
downpipe's Avatar
Default Re: yupieeeee, new awesome dyno numbers for me! (khang77642)
hey bro, haven't talked to you in a while. good job! hope all is well
Old Jun 19, 2003 | 05:30 AM
Default Re: yupieeeee, new awesome dyno numbers for me! (downpipe)
sorry to bring back that old post, but I realy want to know what the highest numbers ever made on a T3/T04e .63a/r stage 3 wheel. 54 a/r compressor? what boost was made?
I guess this Turbo is realy maxed out at 22psi and 420whp. I also think this Turbo is only efficent up to about 370whp on 17psi. I reached the Turbos limit with my setup I guess.
