a more specific question similar to a thread on here already....
Old May 19, 2003 | 11:46 AM
dohc-nyne's Avatar
Default a more specific question similar to a thread on here already....
anyone framiliar with the cel code o2 snesor heater malfunction? i heard that is means that the cat is not getting hot enough to read or sumthin? i got a carsound hi flow cat put on this weekend and it happened imediatley after that...the cat is 2 1/4 inch....will this code make me loose power? or throw my ecu into a limp mode?
Old May 19, 2003 | 02:49 PM
dohc-nyne's Avatar
any help?
Old May 20, 2003 | 04:07 AM
JimBlake's Avatar
Default Re: a more specific question similar to a thread on here already.... (dohc-nyne)
You're talking about CEL code 41??
The O2 sensor has a built-in electric heater, so it heats up faster than the exhaust would heat it. Otherwise it would take too long to heat up & start working. That code just means the heater circuit isn't working. Could be a blown fuse, could be the heating element is busted, or you have a broken wire somewhere.
It's not related to the cat itself. It's not even related to the actual signal from the O2 sensor itself, just the heater.
doubleoazn03
Mar 3, 2018 02:06 PM
nutball72
Aug 10, 2007 03:05 PM
Frostwhite_DB8
Jun 2, 2007 09:33 AM
2k1 SSM GSR
Oct 22, 2004 11:30 AM
Another_Teg_Owner
Dec 15, 2003 11:11 PM
