SOHC Greddy Turbo Kit on LS engine
Old May 19, 2003 | 11:44 AM
SRT-WHORE's Avatar
Default SOHC Greddy Turbo Kit on LS engine
I need to know what exactly is needed to make this work. The SOHC Greddy turbo kit on an Integra LS engine, and intercooler if possible.
Old May 19, 2003 | 11:59 AM
DaveF's Avatar
Default Re: SOHC Greddy Turbo Kit on LS engine (SILINITY16)
you need a new manifold.
Old May 19, 2003 | 01:52 PM
Charlie Moua's Avatar
Default Re: SOHC Greddy Turbo Kit on LS engine (2.2Lcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.2Lcivic &raquo;</TD></TR><TR><TD CLASS="quote">you need a new manifold.</TD></TR></TABLE>
no you don't you just need to modify it slightly to work.
Old May 19, 2003 | 02:17 PM
ATgrills.com's Avatar
Default Re: SOHC Greddy Turbo Kit on LS engine (Charlie Moua)
just grind the ports bigger and slot the wholes to bolt on!
Tyler
Old May 19, 2003 | 11:09 PM
nuport's Avatar
Default Re: SOHC Greddy Turbo Kit on LS engine (ATgrills.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ATgrills.com &raquo;</TD></TR><TR><TD CLASS="quote">just grind the ports bigger and slot the wholes to bolt on!
Tyler</TD></TR></TABLE>
if this is so, how come more people don't buy the sohc kits? don't most of them go for liek $1k less
Old May 20, 2003 | 02:49 AM
Default Re: SOHC Greddy Turbo Kit on LS engine (nuport)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nuport &raquo;</TD></TR><TR><TD CLASS="quote">
if this is so, how come more people don't buy the sohc kits? don't most of them go for liek $1k less</TD></TR></TABLE>
becuase the sohc kit doesn't come as complete as the Bseires kit!
Also they are priced differently due to the turbo it self(15G vs. 18G)
There are some people who have used the sohc kit on their LS and B16a with great sucess but the only concern to address is the loss of power in the upper RPM range (6,000rpms and up)
that little 15G turbo on a LS should reach full boost before 3300rpms and will runn out out boost at about 6k! so after 6k your hp will most likely DROP or flaten out.
Old May 26, 2003 | 04:13 AM
SRT-WHORE's Avatar
On stock internals with the exception of some nice aggressive cams, intake manifold, hondata, etc. what are some expected dyno numbers and if possible 1/4mile times.
yesSiReK
May 4, 2008 07:42 PM
contender
Nov 19, 2006 09:03 AM
b18cEK
May 30, 2005 04:41 PM
b18cEK
May 30, 2005 10:16 AM
Sohc Driver
Oct 17, 2003 01:23 PM
