92-93 ys1 tranny axles and intermediate shaft ???
Old May 19, 2003 | 11:37 AM
chirp2hrd's Avatar
Default 92-93 ys1 tranny axles and intermediate shaft ???
ok im confused i have a 92-95 b16a with a ys1 lsd tranny since the motor came out of an integra in japan can i use the 90-91 integra driver side axle or do i need the intermediate shaft from a 90-91 integra too i am confused about if i need a new intermediate shaft or not cause this motor/tranny came outta 92-93 integra xsi any help would be great
Old May 19, 2003 | 11:50 AM
chirp2hrd's Avatar
Default Re: 92-93 ys1 tranny axles and intermediate shaft ??? (chirp2hrd)
what i wanan know is i have a ys1 tranny can i use 90 91 integ axles wit out 90 93 intermediate shaft and use the ys1 intermediate shaft cause it came out of an integra anyway???
Old May 19, 2003 | 12:40 PM
chirp2hrd's Avatar
ttt
Old May 19, 2003 | 10:27 PM
HybridEarthquake's Avatar
I read recently that the intermidiate shaft is neccesary to stop torque steer under hard accelleration. I'm not sure of the years involved, but if I find out...
Old May 19, 2003 | 10:32 PM
1's Avatar
Default Re: 92-93 ys1 tranny axles and intermediate shaft ??? (HybridEarthquake)
All intermediate shafts are interchangeable from the G2 Integras. You can use any 90-93 Integra axles on them as well.
Old May 19, 2003 | 10:45 PM
civicdragger818's Avatar
Yes you can use the XSI inermediate shaft......The axles are the same on the g2 integra's both usdm and JDM..
Old May 19, 2003 | 11:59 PM
This is stolen from a web site, but go visit them tho get the info:
http://hybrid2.honda-perf.org/tech/4gtech.html The B16A1 is almost identical to the 160hp U.S. Del Sol VTEC (B16A2). The Del Sol motor does NOT bolt in either. Since the D-series transmissions are not compatible with the B-series motors, you should purchase the Y1 transmission along with the motor. If you can, buy the motor and transmission as a package, not separately. Some of the Y1s have the highly desirable factory LSD. LSD should be imprinted on the transmission casing, so search carefully. If a Y1 is not available, a 90-93 Integra LS transmission will work, but the gear ratios are not designed for the high rpm VTEC engine and will hurt acceleration. With either tranmission you will need to modify the shift linkage to fit. A few people have managed to get Si-R shift linkages from Japan and these work perfectly. http://www.hasport.com/News/Ar...s.htm The middle intermediate shaft, comes with B16As that were in 89-91 SiRs. The easiest way to tell if you have one is if you B16A engine serial number starts with a 5, or you transmission has a Y1 sticker on it. As evidenced by the picture comparing the Integra intermediate shaft and the SiR intermediate shaft, you see that the SiR intermediate shaft is about an inch longer. http://userpages.umbc.edu/~bhu....html Good breakdown of the different transmissions available. http://www.sportcompactcarweb....1.pdf honda engine swap guide.
Old May 20, 2003 | 12:09 AM
hope it's helpful
Old May 20, 2003 | 06:52 AM
sleeper4dr's Avatar
Default Re: 92-93 ys1 tranny axles and intermediate shaft ??? (1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 &raquo;</TD></TR><TR><TD CLASS="quote">All intermediate shafts are interchangeable from the G2 Integras. You can use any 90-93 Integra axles on them as well.</TD></TR></TABLE>
all manual intermediate shafts are interchangeable from the G2 integras. Auto intermediate shafts will not fit into a manual trans AND bolt to the back of the block.
Old May 20, 2003 | 06:59 AM
1's Avatar
Default Re: 92-93 ys1 tranny axles and intermediate shaft ??? (sleeper4dr)
Thank you sleeper4dr. I should have clarified this. I figured he probably already thought that part. assuming=
BWek
Dec 7, 2007 05:15 PM
NAIIAWAH
May 16, 2006 06:39 PM
Ransom
Apr 8, 2004 02:27 PM
SiZ
18
Jan 31, 2004 02:25 PM
Black R
Dec 2, 2002 05:04 PM
