Ys1 cable tranny what axles? 96 hatch
hey guys i have an avid kit to put my ys1 in my car and was wondering waht axles do I run? i know the half shaft is different from a hydro tranny
Do i run 90-93 integra axles?
its a 96 hatch
its a 96 hatch
Re: Ys1 cable tranny what axles? 96 hatch (watsvtecEK)
Can i use Just any kind? i don't have one yet can Do i need to use one from a 90-93 integra or 94-01 integra I know they are different I have access to both I haven't bought the halfshafts or cv shafts what the best/easiest soloution?
Re: Ys1 cable tranny what axles? 96 hatch (BWek)
the pass side there is no difference unless you have ABS, but if you are you using the 90-93 integra half shaft you dont have to do anything, but if you use a 94+ integra half shaft you have to change the axle seal on the driver side of the tranny.
good luck
good luck
So if i use a newer half shaft (which i assume will be easier to get) just pop the old seal out and get a new seal from a hydro tranny
And any integra axes will work I do not have abs
Also my car is an automatic at the moment the hubs are the same right? i know the older cars the hubs had to be swapped
thanks for all the help guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BWek »</TD></TR><TR><TD CLASS="quote">So if i use a newer half shaft (which i assume will be easier to get) just pop the old seal out and get a new seal from a hydro tranny
i dont think you have abs, no you dont have to change hubs, and yes you just have to change the seal if you use newer axles
chirp2hrd
05-20-2003 06:59 AM
