Going to the Ref Today!
Old May 19, 2003 | 10:00 AM
acuracing's Avatar
Default Going to the Ref Today!
Oh joy. Heading off to the ref to finally get my BAR sticker. We'll see how things go. It's a B18C5 in a 92 EH2. Everything is wired for OBDII. No codes have been thrown for a bit. Let's hope it stays that way. Damn California.
Old May 19, 2003 | 10:04 AM
dkim48's Avatar
Default Re: Going to the Ref Today! (acuracing)
good luck bro. I should be doing the same in about a month or so.
joe_bocc's Avatar
Good luck! Is it a stock motor?
Old May 19, 2003 | 10:05 AM
-Gambit-'s Avatar
good luck! Keep us updated on if you pass.
Old May 19, 2003 | 10:06 AM
skribblah's Avatar
be sure to heat that cat up!
Old May 19, 2003 | 10:11 AM
acuracing's Avatar
Default Re: Going to the Ref Today! (joe_bocc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joe_bocc &raquo;</TD></TR><TR><TD CLASS="quote">Good luck! Is it a stock motor?</TD></TR></TABLE>
Yeah. Only thing I have is AEM CAI, but it has a CARB number so I'm fine.
Old May 19, 2003 | 10:14 AM
tonyxcom's Avatar
what ecu are you running and what did you do about the fuel tank pressure sensor?
Old May 19, 2003 | 10:22 AM
acuracing's Avatar
Default Re: Going to the Ref Today! (tonyXcom)
Running a '00 USDM P73. For the FTPS, I used one off of a 96 Civic. I have a Type R fuel tank, but I didn't put it in the car. I ran all the electronics off the stock 92 tank, and used the ports on that to connect to the hoses for the OBDII EVAP system. Everything is wired up and all the hoses are run to their respective places.
Old May 19, 2003 | 10:24 AM
tonyxcom's Avatar
But there is a sensor on the tank isn't there?
I guess you also have the immobilzer circuitry in your car too
Old May 19, 2003 | 10:28 AM
acuracing's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tonyXcom &raquo;</TD></TR><TR><TD CLASS="quote">But there is a sensor on the tank isn't there?
I guess you also have the immobilzer circuitry in your car too </TD></TR></TABLE>
From what I took out of the service manual, there was no electrical plug on top of the fuel tank, as in no plug around the area under the seat bottoms near the fuel pump. The vacuum port that existed on the OBDI tank which was a part of the OBDI EVAP system was used for the OBDII EVAP system. Sort of just plug and play, with wires galore!
I'm sorry I was mistaken for the ECU is a 98.
Old May 19, 2003 | 10:29 AM
B_CRUZ!'s Avatar
re-set your ecu before going if you threw a code a while back and didn't re-set it. since you converted to OBD2, is there a spot for them to hook up the scanner?
if you fail there, re-test in Alameda at the college. They are a lot more leanient than the other places.
Old May 19, 2003 | 10:31 AM
acuracing's Avatar
Default Re: Going to the Ref Today! (BCRUZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BCRUZ &raquo;</TD></TR><TR><TD CLASS="quote">re-set your ecu before going if you threw a code a while back and didn't re-set it. since you converted to OBD2, is there a spot for them to hook up the scanner?
Reset it quite a few times before. No codes have been thrown for quite some time now. And yes, I have the DLC (Data Link Connector) wired up under the dash by the center console.
Old May 19, 2003 | 10:32 AM
B_CRUZ!'s Avatar
run 87 or 89 octane and good luck.
Old May 19, 2003 | 10:34 AM
acuracing's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BCRUZ &raquo;</TD></TR><TR><TD CLASS="quote">run 87 or 89 octane and good luck. </TD></TR></TABLE>
Last time I ran lower octane the knock sensor flared up. Running 91 clears all problems for me.
Old May 19, 2003 | 11:17 AM
B_CRUZ!'s Avatar
then go with what works. also to make sure you pass, pre-test at a gas station first to see where you stand sniffer wise/.
eg6T
Dec 1, 2004 12:02 AM
undertheradar
Nov 22, 2004 10:15 AM
patastinky
May 3, 2004 10:19 AM
EF_LSVtec
10
Jul 22, 2002 11:23 AM
acuracing
Apr 11, 2002 04:31 PM
