B16a1/B16a2 hybrid is this possible?
I have read another thread on here about the differences between the a1 and a2 B16 motors. I have a B16a2 and the rings are shot to hell.
As the a1 engine has different pistons and lower compression ratio, If I fit my B16a2 head which is polished. ported and milled(?) down,will this offset what compression I would lose from the pistons?
Obvioisly I would use my a2 cams as they are higher lift and longer duration.
Please don't flame me, as over here in England auto shops charge the earth to work on motors if they are japanese and parts are way expensive. The a1's go for half the price of a2's.
I just want an easy fix and have the same power I enjoy now.
Thanks in advance!
Thanks in advance!
You can do that. You can also get a some CTR pistons. Raise your compression. Milling the head is fine, aslong as you know how far to go. Your plans sounds reasonable enough.
Also, I'm not sure what the European B16A2 motor's compression is, but over here it is 10.2:1 which is exactly what the B16A1 motor's compression is. SO more than likely, you won't be losing any compression. Now, I guess you could have 10.4:1, but it's not that big of a difference.
You can find brand new CTR pistons for $250 US dollars here.
t0n
Nov 13, 2006 10:52 PM
. WAAS_SAPPENING
15
Jun 12, 2006 06:51 PM
jsalicru
Dec 20, 2002 03:13 PM
