raising compression in b16a2
Is there a way I can get compression up to 12:1 with the stock b16 81mm bore? Or do I have to raise the displacement?
Re: raising compression in b16a2 (1slow4door)
Yep, that will do it. when you mill the head, just make sure you time your cams properly if it has some crazy duration.. You can make the exhaust and intake valves hit due to the overlap.... seen it happen.. Just a friendly reminder
Modified by 4DeepCivic at 6:47 PM 5/16/2003
slamdunkcivic
05-20-2003 06:26 AM
jsalicru
12-20-2002 03:13 PM
EFing8
10
12-14-2002 04:00 PM
