Running high compression with stock cams?
Old May 19, 2003 | 07:51 AM
Shorty C's Avatar
Default Running high compression with stock cams?
So its like this
car:99 si coupe
motor:b16a2
problem:1.6 torque =
plans: drop 1.8 gsr block with std size ctr pistons w/ mugen head gasket
question: I was wondering if it would be safe to run high compression on the stock b16 cams, my funds are a bit little to do everything at once. I plan to add in bigger cams with valvetrain but I dont know which is the best way to go first or is it better to do EVERYTHING at once?
Also I know of some issues with the vavle to piston clearance issues. I plan on running skunk2 stage 2 cams with full valvetrain. Any key pointers that I should be aware of?
Sorry if I sound newbish because I am, I just dont wanna rush into building my motor because unsure decisions cost more money in the long run and I wanna learn as much as I can before I dive into my motor's internals.
Thanks in advance
Old May 19, 2003 | 10:03 AM
joe_bocc's Avatar
Default Re: Running high compression with stock cams? (sykol)
High compression with stock cams will not hurt anything. Just don't go crazy.
esurds
Feb 11, 2010 07:42 PM
bugster
Jan 28, 2005 04:53 PM
jdmcx
Dec 21, 2003 06:34 AM
quikyEG
Aug 9, 2003 12:08 PM
Unsung
Feb 15, 2003 01:26 PM
